Old December 21, 2009, 08:12 PM
Dazmode's Avatar
Default Feser One 6 months experiment
I decided to re-do my main rig and upgrade my Supreme block to full copper version.
System was used heavily for 6 months with Acid Green Feser One coolant. As there were numerous complains on Xtreme forum, I was quite curios to open my block to see if there is any goo or other crap inside.
Happy to report that my supreme is pristine clean and just oxidited (darker in color). I will post U-tube video shortly.
Canadian Watercooling Store
Dazmode YouTube Channel
HAF932 Black Painted | GA Extreme w/EK Chipset Block | i7 920 w/ EK Supreme Block | 6Gb G.Skill | 2x285GTX w/EK GPU Blocks | Feser 360 | Acid Green Tubing| - U-Tube worklog
Antec 902, EVGA X58, i7, 6Gb, 1T RAID1, HD4870 1Gb, Watercooled: Supreme LT, TFC240, 655-B with EK Top, San Ace 3k rpm, EK-Multires
Antec Fusion |i5| HD4870|HT Striker| BLURAY| Passive Cooling| - HTPC
Old December 21, 2009, 11:20 PM
cozmosland's Avatar
thats good to hear, i kept hearing the same thing and i really wanted to use their blue coolant.
thanks alot :)
Old December 22, 2009, 10:25 PM
JD JD is offline
Mines been clean too with UV Blue Feser One.
There was only ever some minor, and I mean like 1 piece, of "gunk" in my CPU block the first time I flushed it, but I'll admit, I didn't exactly clean/flush any of the new stuff before I installed everything. So it was probably due to that.
Old December 23, 2009, 08:47 AM
Hey.
I use Purple feser one and have never had a problem. I also am currently using black and green in other rigs with no problems.
The one rig I made was for a friend and he gave it to me to clean a while back and it had been using the same feser one purple coolant for over a year and a bit.. It was completly clean and gunk free..
Feser Rocks
Old December 23, 2009, 08:50 AM
I switched to using distilled water only with primochill tubing (supposedly has pre-applied biocide in the tubings).. since I've been hearing this thing about Feser liquid is corrosive and damage your stuff.. So it's a relief to know, nothing is wrong with it..
Although, I did use one bottle of the UV pre-mixed coolant before, and found nothing like gunk or dirt in my blocks when I drained my loop, except for the cpu block internals needed to be washed to take of the blue color.. Even the liquid that I drained was pure blue, and no dirt..
Thanks Daz..
Old December 28, 2009, 09:58 AM
When I got my feaser UV red coolant I noticed in the bottle before opening that there was some junk like dust bunnies floating in the liquid. I just used a coffee maker filter to clean it out and so far no issues.
Core i7 970 @ 4.2 GHz
Asus P6X58D-E
12GB Corsair XMS3 Dominator DDR3-1600
ASUS DCII GTX 580 EVGA GTX 580 SLi Surround | Dell 2709W (x3)
OCZ Vertex 3 240Gb - Windows 7 x64 SP1
OCZ Vertex 120Gb - Steam Drive | Seagate 2Tb - File backup
Corsair Obsidian 800D | Enermax Revolution85+ 1050W
HeatKiller 3.0 | TFC Exchanger Quad Rad | Thermochill PA120.3 | (x7) Scythe Gentle Typhoon |Swiftech MCP655 | EK drive bay Res.
Old December 29, 2009, 08:11 AM
KaptCrunch's Avatar
wrong link to claim
IMHO is a worthless review
video has inconsistency
not a start to finish rec job
Old December 29, 2009, 08:46 AM
Dazmode's Avatar
Too much work to stage continuous and clean video (dog is barking, wife is yelling, kids are screaming...), plus u-tube has 10 min limitation. So, there is perfect world and there is real life.
What is matter for me is that I've seen result with my own eyes and it clear for me personally.
Old December 29, 2009, 09:11 AM
JD JD is offline
Originally Posted by KaptCrunch View Post
wrong link to claim
Feel free to make your own video then. If he staged it he would of had to take apart the block, clean it all out and put it back together then dripped some liquid back into it. It seems like a lot of effort to do when I doubt he's on Feser's payroll.
I too have used Feser One for easily 6 months, probably closer to a year now. Only gunk I had was after the first month or so when I drained it, but I'm fairly sure that was my fault of not exactly cleaning anything out. I try and drain it every 6 months though, and typically I have something new by then anyways
Old December 29, 2009, 09:23 AM
KaptCrunch's Avatar
not with my setup, can't run any freezing fluid for my rads are outside...today its -15c
How to dye water cooling tubing *Experiment*IKIKUINTHENUTZ IKIKUINTHENUTZ Water Cooling 3 September 19, 2009 06:35 PM
no boot/ no display for 6 months Sicotic Troubleshooting 25 April 21, 2009 01:09 PM
Conquered my UNSTABLE_MACHINE after ~4 months :) frontier204 HardwareCanucks F@H Team 8 March 1, 2009 03:58 PM
Building a new rig 2 years after the great laptop experiment undertow New Builds 15 February 2, 2009 07:36 AM
Opteron Experiment xrmarcis CPU's and Motherboards 8 September 24, 2007 01:44 PM
