  #21 (permalink)
Old December 13, 2009, 10:58 PM
I read that the 355 is kind of loud that is why I wanted the 350 is this true.
Please visit my website at www.GamerForumZ.com we are currently having a $20 giveaway.
  #22 (permalink)
Old December 13, 2009, 11:01 PM
HaDeS
Guest
Posts: n/a
Originally Posted by [email protected] View Post
If he plans on over-clocking any, a triple is almost a must for the i7. These puppies run hot. My i7 920 @3.8ghz(1.31v) with HT and Turbo on runs about 50c at full load (HWLabs SR1 360 with 3 Scythe S-FlexG-74cfm at 12v) Fans at 5v she hits 65C.
cool thanks... i didn't realize they ran that hot. I noticed the link to the glycol liquid you were gonna use... let me be the 1st to tell you sir. You can buy that stuff from any automotive shop for around 10 bux. It's pre mixed antifreeze and I use it in my loop.
  #23 (permalink)
Old December 13, 2009, 11:12 PM
Thanks for letting me know I doubt I need antifreeze though it never gets anywhere close to freezing here especially in my house.
  #24 (permalink)
Old December 14, 2009, 08:04 AM
Synth's Avatar
Any pump sitting, or attached directly to metal will make vibration noise.
It's not loud if you isolate the vibration. I usually stick little round fluff pads that can be had at Home Depot at the base of my pump (if you lay it flat at the bottom of your case, of course). Makes it silent.
  #25 (permalink)
Old December 14, 2009, 06:50 PM
I was going to use this plate to mount it in a hdd slot Newegg.com - StarTech BRACKET25 Adapter Kit to Mount 2.5" HDD in 3.5" Drive Bay - Case Accessories and also the tubing I put up a link for a few posts back says compression fitings wont work with it. Is that true and why not? Thank you.
  #26 (permalink)
Old December 14, 2009, 06:57 PM
Dazmode's Avatar
Are you using IDE laptop hard drive?
Id sata you need something like that:Newegg.com - StarTech HSB220SAT25B 2 Drive 2.5in Trayless Hot Swap SATA Mobile Rack Backplane - HDD Accessories
Orange Build: Final Video
HTPC Build: Final Video
  #27 (permalink)
Old December 14, 2009, 07:09 PM
I am not going to mount a hard drive in ther my pump is going to go in there.
  #28 (permalink)
Old December 14, 2009, 07:42 PM
Dazmode's Avatar
Then you better off with EK X-top, then this thingy.
Watercooling GPU Advice AdoP Video Cards 8 October 28, 2009 05:06 PM
Watercooling Question/advice homer98 Water Cooling 9 August 26, 2009 02:01 PM
Advice/comment on my watercooling loop LC0g Water Cooling 29 May 28, 2009 05:53 AM
Watercooling Help EDMCR Water Cooling 24 August 3, 2008 07:24 AM
WaterKegIII Extreme external Watercooling unit, Watercooling stuff Apollo4g Buy/Sell & Trade 9 June 9, 2008 09:49 PM
