Originally Posted by Jackquelegs The problem is when you can spend the same amount of money essentially, and grab a Typhoon III, or Detroit Thermos for the MCP655 for better performance  |
Screw it all and just get an Iwaki RD-30
Originally Posted by smp420 I decided on the 350 actually because I dont have room for a bigger pump. My rad takes up most of the space in my case and I dont want a smaller one. I think I might still get the thermaltake resevoir as I cant find a better one. Is there a reason I should stay away from the coolant I listed I kind of like that it is non conductive. Thanks for the help.
edit-I did some more reading and found out that nonconductive coolant will eventually become conductive anyways so will just use distilled water. |
Still try to find a nice top for that MCP350 - since you already picked it. I really would recomend something other than that ThermalTake Res, but hey, its your build, you pick what you want
If that res stands out to your - take it!
If you absolutly go with colored fluint Feser One is your friend. I spilled that
all over my 4870X2. I wiped it, let it dry, and there is nothig wrong with that card, nothing was fried
Also, the colored stuff does stain tubing and blocks, and sometimes will cause build-up and clog still - this doesnt always happen, but it can, and has.
Truely just go for colored tube, and spend the $2 on 4L of distilled water from a drug store or something. Oh yea, if you go with distilled water you
WILL NEED some sort of bio-cide, fungi-cide, crap-o-cide to keep algae and gross stuff growing. One of these is all you need, or two if you want to be extra safe
NCIX.com - Buy Bitspower -TRUE SILVER- G1/4 Straight Compression Fitting for 3/8IN ID 5/8IN OD Tube Silver Plated - BP-SLCPF-CC3 In Canada. NCIX.com - Buy Bitspower -TRUE SILVER- G1/4 Straight Compression Fitting for 1/2IN ID 3/4IN OD Tube Silver Plated - BP-SLCPF-CC5 In Canada.
