Old September 21, 2007, 01:32 PM
Infiniti's Avatar
Default Good Temps for WCed PC?
Well, I was just wondering if these temps on idle are OK... BTW its winter...
System: -65C (I do not know why the temp is that..)
CPU: 30C (sometimes goes to 31C)
AUX: 36C
Core0: 15C
Core1: 15C
On full load, the temps go up to:
System: -65C
CPU: 41C
AUX: 36C
Core0: 30C
Core1: 27C
BTW, I use the watercooling.....swiftech H20-220 Apex Ultra with the Swiftech Storm CPU block
Old September 21, 2007, 02:26 PM
sswilson's Avatar
Temps look fine to me.
Old September 21, 2007, 04:35 PM
3.0charlie's Avatar
For an oc'ed E6750, you have great temps.
Old September 21, 2007, 08:34 PM
Infiniti's Avatar
K, thanks
Old September 21, 2007, 08:37 PM
3.0charlie's Avatar
using Speedfan, right? the -65C is a bug. don't worry about it.
Old September 21, 2007, 08:41 PM
Infiniti's Avatar
K xD.... Is there anyway to fix that bug? I wanna know that temp
Old September 21, 2007, 08:50 PM
3.0charlie's Avatar
Fix it? no way that I know of. But if I'm not mistaken, the system temp is the Aux temp in Speedfan.
You must have great air flow. Gotta love (and hate!) the P180/P182. You better post pics in our WC gallery! I wish to see your setup.
John
Old September 21, 2007, 09:10 PM
Infiniti's Avatar
I dont think you would wanna see my rig xD... its hell inside... so messy
Old September 22, 2007, 06:33 AM
3.0charlie's Avatar
Better take care of your wiring / hose management, otherwise the system temps will sky-rocket.
Old September 22, 2007, 05:21 PM
Infiniti's Avatar
Hehe, I just rer-routed my cables/wires from the back and now the inside looks AWESOME But I dont notice much temp changes.
temps Kassela Troubleshooting 7 March 13, 2008 02:46 PM
Question about my temps crazyazn Overclocking, Tweaking and Benchmarking 16 March 3, 2008 01:33 PM
Northbridge Temps bobcat Water Cooling 9 February 6, 2008 05:26 AM
GPU temps Infiniti Water Cooling 1 December 23, 2007 09:10 AM
ram temps? bushwickbill RAM 5 August 31, 2007 05:35 PM
