<~----> Going under water for the first time, part 2: moving to a new home - Page 8 - Hardware Canucks
  #71 (permalink)
Old October 14, 2010, 11:44 AM
chrisk's Avatar
Folding Captain
I would not be using a triple rad for just a cpu normally; I will be adding two video cards to the loop in the future.
Fold for team #54196
  #72 (permalink)
Old October 14, 2010, 02:14 PM
Sagath's Avatar
460's dont count as 'adding to the loop' considering they fold at sub 60c temps :P
Originally Posted by Lpfan4ever View Post
AKG shot the hamsters, and then Perineum drove his Mustang with summer tires into the server.
  #73 (permalink)
Old October 14, 2010, 04:18 PM
lowfat's Avatar
Answer to both of these is you are not overclocking high enough.
  #74 (permalink)
Old October 14, 2010, 06:39 PM
Sagath's Avatar
My 460's wont do over 930mhz and thats at 1.2 Vcore!
  #75 (permalink)
Old October 14, 2010, 07:42 PM
lowfat's Avatar
No matter what clocks mine are at they won't even run @ 1.212V. Lock up after a few minutes no matter what.
  #76 (permalink)
Old October 14, 2010, 07:45 PM
chrisk's Avatar
Folding Captain
Who knows; if the 460s I have run really cool, and I can't hear them over the rad fans, I might not stick blocks on em after all.
  #77 (permalink)
Old October 14, 2010, 08:03 PM
Xeven's Avatar
They run cool, especially with the adv units. I tried 4 of them at once in bench and they only do around ~55C, 0.937V, standard SC clocks (763 Mhz) without a blower on top. I can't give figures inside a case since my 690 II can't accomodate all four of them. I'm waiting for a P50 so I can put all four of them online. Hopefully they won't roast each other
PSXeven. Batards of the World Unite!
The gap between happiness and utter misery is only but a few inches
  #78 (permalink)
Old October 14, 2010, 08:12 PM
Sagath's Avatar
I have 2 inside my case, both fold (one slot apart) at sub 60c. Usually closer to 55c depending on ambient.
You really don't need to WC them Chris, even in your apartment. They put sweet F-A out for heat. Save the cash. Trust me.
  #79 (permalink)
Old October 14, 2010, 08:29 PM
lowfat's Avatar
This can't be on stock cooling.
  #80 (permalink)
Old October 16, 2010, 12:33 PM
chrisk's Avatar
Folding Captain
Leak testing right now. I like the look of compression fittings...too bad I did not have enough for the whole loop. The top makes the 655 pump look much better too (picture soon). I did have a leak straight away, due to one fitting coming loose while putting in another..noob mistake, but the leak did not touch any components.
I hear that 24 hours is suggested for leak testing...is it a terrible idea to go with just 6-7 hours?
Low Consumption Folder OR Part time POWER Folder ilya New Builds 3 May 16, 2010 03:33 PM
Home made i7 water block Lazypixel Water Cooling 30 March 11, 2010 06:57 AM
home made gpu water block Lazypixel Water Cooling 24 July 11, 2009 07:50 PM
Moving to a new place, Should I take out my CPU cooler for moving? appplejack Air Cooling 5 March 10, 2009 02:44 PM
Water not moving Infiniti Water Cooling 17 January 2, 2008 10:35 AM
