  #61 (permalink)
Old October 13, 2010, 09:17 PM
Arinoth's Avatar
Originally Posted by Sagath View Post
Goddamn rich teachers and their Union Protected Jobs.
Coming from the guy who is being paid to go to school right now mr military?
  #62 (permalink)
Old October 14, 2010, 04:18 AM
chrisk's Avatar
Folding Captain
Haha you suckers keep buying Leafs' tickets so I will be rich when I retire too.
Fold for team #54196
  #63 (permalink)
Old October 14, 2010, 05:50 AM
Originally Posted by chriskwarren View Post
5. HAF 932 ---> ATCS 840
Ooooooh nice! I'm adding an internal double rad in addition to the triple at the top fairly soon!
http://www.thecomputermadesimple.com | The computer world in plain English!
  #64 (permalink)
Old October 14, 2010, 07:25 AM
Keywork's Avatar
I was just about to make a post asking something but the above post kind of touches on it. I too own an ATCS 840 and i'm in the middle of purchasing parts. For a CPU only loop (i7 920 running at 3.8), would a triple be good? I know the answer is yes, but i'm contemplating purchasing an MCR220 to stick in front of the drive cages as well, for a total of 5x120mm rads.
Is this overkill or what?
  #65 (permalink)
Old October 14, 2010, 07:37 AM
matsta31's Avatar
Only for the CPU ? It would not be overkill, it would be extreme overkill.
Sold hardware again.....
Currently using WHS hardware....
  #66 (permalink)
Old October 14, 2010, 07:39 AM
Right now I've got a triple rad at the top with a single one at the bottom cooling and OCed i7 920 4.0 GHz, mobo full cover block, 5870 and 460. Temps under load for cpu around 65 and 460 when folding is 45. So yes it's overkill, but I'm doing it anyways. (I'm actually making a second loop just for my video cards)
  #67 (permalink)
Old October 14, 2010, 07:47 AM
matsta31's Avatar
Just to be clear, I believe overkill is fun when it comes to watercooling. But is is still overkill !
  #68 (permalink)
Old October 14, 2010, 07:56 AM
Keywork's Avatar
Hmm... haha well then. I'll still think about it before I make an order in a few hours. Also, what fans are you using out of curiosity? I'm going with S-Flex 1600's as I already have 2 on the HDD cages.
  #69 (permalink)
Old October 14, 2010, 08:47 AM
Same, but might make the switch to Gelid UV ones just for looks.
  #70 (permalink)
Old October 14, 2010, 10:17 AM
matsta31's Avatar
I used to have Yates loons, because they were cheap and had good static pressure. I also used some cooler master for the same reason.
The marginal difference with more expensive fans was not enough for me to justify it. Altough, other user will swear some fans are better and worth it.
Low Consumption Folder OR Part time POWER Folder ilya New Builds 3 May 16, 2010 03:33 PM
Home made i7 water block Lazypixel Water Cooling 30 March 11, 2010 06:57 AM
home made gpu water block Lazypixel Water Cooling 24 July 11, 2009 07:50 PM
Moving to a new place, Should I take out my CPU cooler for moving? appplejack Air Cooling 5 March 10, 2009 02:44 PM
Water not moving Infiniti Water Cooling 17 January 2, 2008 10:35 AM
