  #21 (permalink)
Old December 8, 2009, 08:35 AM
bissa's Avatar
I keep reading the title and thinking you are going scuba diving. nice rig though, it will be interesting to see the final product.
Strong like hummingbird, swift like oak.
  #22 (permalink)
Old December 8, 2009, 09:13 AM
biff's Avatar
Not sure of the similarities in the HSF between the gtx285's and 280's but I was so happy to get my 280 on water... can't imagine 2!
Q6600 @ 3.83GHz w/ D-Tek Fusion
Asus P5Q-PRO
2x 2GB PC8000 Mushkin Redlines @ 1020MHz w/5-5-5-12 timings
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Cooler Master Cosmos on water
  #23 (permalink)
Old December 8, 2009, 02:37 PM
bkh2's Avatar
You have just the Asus P6T right? Not SE, Deluxe, etc, just the normal P6T? If so, I don't think there are any northbridge blocks that fit that board. If anyone knows otherwise, please let me know. Looking forward to pics as well. I just bought and painted a HAF 932 and will be moving my rig into it in a couple of weeks.
  #24 (permalink)
Old December 8, 2009, 08:33 PM
chrisk's Avatar
Folding Captain
Nope just the normal P6T.
No pics tonight as the rig is not done yet. We will head to kruzn's bunker tomorrow to finish her up.
Fold for team #54196
  #25 (permalink)
Old December 9, 2009, 02:38 AM
Jackquelegs's Avatar
Iapetos
Zephyranthes
  #26 (permalink)
Old December 9, 2009, 07:47 AM
HaDeS
Guest
Posts: n/a
Oh this looks like a good project. Subscribed.
  #27 (permalink)
Old December 10, 2009, 02:57 PM
chrisk's Avatar
Folding Captain
Default E're she is
Rig is now under water.
I know typically its CPU first, but the loop goes into the video cards first, since that was what I wanted cooled the most with all the folding abuse they take. At kruzn's house my video card temps were at 40c-42c while folding some 353 pointers. This used to be at 85c so I would say there was some marginal improvement there. This also seemed like an easier loop to do.
The cpu was at 60c while doing a bigadv (OC to 3.4GHZ, 1.2v), so that was a little better than the 70c they would see normally. These temps will rise when I put the rig back under the desk too, so hopefully they won't go much higher when I try for 4.0GZ next week.
The major difficulty encountered was that the Apogee GTZ block's mounting screw got stripped real easy. One of the threads never did catch properly, so Swiftech is sending a new bracket and rear mounting plate no questions asked (never asked for an invoice or anything). Good customer service I would say, but by looking at reviews of this block and through some forums, plenty of folks had this issue with the screws getting stripped easy. In the meantime, I bought Kruzn's Alphacool Niagara cpu block instead, and will use the Apogee in the folding rig this winter or spring.
Here are the pics. Sorry about the flash but the lighting is poor so I tried taking shots from angles to help with that:
Here is the front for a look at the res and fan controller:
Again, thanks Kruzn4evr for doing this!
  #28 (permalink)
Old December 10, 2009, 03:05 PM
3.0charlie's Avatar
Well done Chris. Enjoy the low temps and silence.
  #29 (permalink)
Old December 10, 2009, 03:14 PM
King Krunz Lee at it again.. Wow Chris it looks really nice.. I have a GTZ to install too, I hope mine doesn't get stripped..
Red tubing looks great, no UV lights ?
I was reading a triple rad roundup part 2 at skinee labs, and that hw labs sr1 360 rad you guys used, he was simply impressed with it, said it performed very well on all fan speeds...
Those EK gpu blocks, I got one running on my 4870, and it cools.. my temps were basically down from the 65Cish to max 40Cish.. Surprised your cpu temps dropped almost in half..
Good to see one more on the dark side ... muhahahaha :p
  #30 (permalink)
Mmm that's clean!
Enjoy yourstay at the darkside
Iapetos
Zephyranthes
Low Consumption Folder OR Part time POWER Folder ilya New Builds 3 May 16, 2010 03:33 PM
Home made i7 water block Lazypixel Water Cooling 30 March 11, 2010 06:57 AM
home made gpu water block Lazypixel Water Cooling 24 July 11, 2009 07:50 PM
Moving to a new place, Should I take out my CPU cooler for moving? appplejack Air Cooling 5 March 10, 2009 02:44 PM
Water not moving Infiniti Water Cooling 17 January 2, 2008 10:35 AM
