-   Water Cooling (https://www.hardwarecanucks.com/forum/water-cooling/)
-   -   Help Me Choose My Fittings Please. (https://www.hardwarecanucks.com/forum/water-cooling/26160-help-me-choose-my-fittings-please.html)
JORD4N December 2, 2009 07:15 PM
Its going in a Corsair 800D Case with Evga sli le mobo, 12G Corsair Dominator 2000mhz with the i7 920 @ 4.5ghz Currently at 3.9 with the Corsair h50.
When do i plan to buy this ? as soon as i get a resonse with the barbs i need to buy http://forum.watercoolinguk.co.uk/im.../icon_wink.gif
Note: Ill be getting a diffrent Cpu block so ignore the fact that there are 2x 45 and x2 straight fittings for the cpu as ill need them.
http://www.watercoolinguk.co.uk/cata...oducts_id=1487
http://www.watercoolinguk.co.uk/cata...oducts_id=1126
http://www.watercoolinguk.co.uk/cata...roducts_id=473
http://www.watercoolinguk.co.uk/cata...roducts_id=346
http://www.watercoolinguk.co.uk/cata...oducts_id=2060
http://www.watercoolinguk.co.uk/cata...roducts_id=965
http://www.watercoolinguk.co.uk/cata...oducts_id=1646
Barbs Are These Correct ?
x1 - WaterCooling UK: 1/4" BSPP - 3/8" ID - 5/8" OD 90 Degree Rotary Compression
x5 - WaterCooling UK: 1/4" BSPP Male Rotary - 45 Degree Female 1/4" BSPP
x9 - WaterCooling UK: 1/4" BSPP - 3/8" ID - 5/8" OD Compression Fitting
My graphic design :rofl:
http://img259.imageshack.us/img259/8...rbsdetaild.png
JORD4N December 4, 2009 09:59 PM
:dots:
sascwatch December 5, 2009 06:21 AM
That should be enough fittings for that setup, I have always thought to stay away from 90* angle fittings, but I'm new to watercooling aswell so maybe they don't have as much of an effect as I think.
With my 800D i used 5 rotaries and the rest were all straight compression fittings.
KaptCrunch December 5, 2009 10:00 AM
yes its a no no to have elbow on the pump inlet
Lpfan4ever December 5, 2009 12:11 PM
Take another look at the radiator fittings as the Thermochill radiators use G3/8 fittings and not the G1/4 you have linked. Also, 90* fitting is a big no-no on the pump inlet, as stated before.
As well, that 5 1/4" bay reservoir is out of stock, and I really don't like trying to fill bay reservoirs.
