Old January 27, 2010, 10:38 AM
I picked one up.. it squeeled.
Took it back.
Old January 27, 2010, 11:57 AM
I recently got the FC5 and am happy to report zero squealing issues. I have 3 fans on one channel and it handles them like a champ.
heatware
ebay
Old January 27, 2010, 04:52 PM
May I ask where you bought it from? I've been searching for an FC5 but I can't find one for sale in Canada anywhere.
Old January 27, 2010, 07:11 PM
JD JD is offline
Originally Posted by BigDogg View Post
Just wanted to add to this thread. I just bought the Lamprton FC3 from directcanada.com to replace my Sunbeam Extreme. Big mistake, the Lamptron has the worst squeal and its going to drive me nuts. My fans have to be turned up to almost full before the squeal goes away. I have emailed Lamptron but I might just RMA the unit (within 30 days) and try and get another Sunbeam (black seems to be out of stock everywhere).
Yup same here. Really disappointed. I have the FC4 though.
It was only like $20-25 though, so whatever. No big loss.
Old January 27, 2010, 07:20 PM
BigDogg's Avatar
Ya I am sending mine back for RMA.. I am going to try and get another Sunbeam so far it has been the best fan controller out of the bunch for me.
Old January 27, 2010, 08:03 PM
Does the FC5 squeal with a low power draw though?
Old January 27, 2010, 11:36 PM
Nope , i tested it thoroughly before i installed it. I even tried 3 Panaflo Ultra speed 120mm fans on a single channel(2.05Amps draw) with no issues.
heatware
ebay
Lamptron FC-5 prototype gets the go ahead for launch! Spawne32 Air Cooling 17 December 23, 2009 09:46 PM
Lamptron FC-2 fan controller mod (so it looks nicer on cases) IKIKUINTHENUTZ Cases 5 July 22, 2009 05:17 PM
How-To: Make Homemade Fan Controllers arekieh Guides & How-to's 25 February 12, 2009 02:12 PM
Question about fan controllers… Gameplaywarrior Air Cooling 13 October 3, 2008 05:54 PM
