<~----> I want to revamp my WC setup - Hardware Canucks
Old November 22, 2009, 09:31 PM
Default I want to revamp my WC setup
http://i300.photobucket.com/albums/n...d/100_1852.jpg
Everything is Swiftech, all red fans Noctua.
MicroRes V2
MCR320
Swiftech GPU Cooler (forget the model)
Apogee GTZ
655 pump
So my main concern is the res, it's currently in the disc drive area, how are drive res's? Those look so convenient and perfect for my loop.
The pump also blocks allot of the space, smaller but just as quiete pump? I'm willing to spend $$$.
Thanks
Old November 22, 2009, 10:13 PM
You could put the pump underneath and the res out a bit further, sorta sticking out.
Old November 22, 2009, 10:15 PM
MpG's Avatar
MpG MpG is offline
It's actually pretty hard to beat the 655 for it's noise-to-performance ratio. Sure, it's big and it dumps a little extra heat in your loop, but it's also a little quieter than its closest competitor - an MCP355 with an aftermarket top, which would probably set you back over $100, for negligible gain. You might consider something like the Primochill T3, which for the cost of two drive bay spaces, will directly accept your current pump and handle reservoir duties.
Old November 22, 2009, 10:16 PM
This T3 pump/res, how good is it? Comparable to the performance/noise of the 655 and Micro Res V2?
And can it support compression fittings?
Old November 22, 2009, 11:19 PM
MpG's Avatar
MpG MpG is offline
No, the T3 is only the reservoir unit - it accepts your current pump (after you've unscrewed the housing). I don't believe it has any issues with compression fittings, although there were a few reports of people needing to use thicker o-rings in a few cases, I think.
Old November 23, 2009, 04:42 AM
AmuseMe's Avatar
Or you can use two o-rings (I would still use one thicker one). Also, Teflon tape
DEAD CA$H
Old November 23, 2009, 07:24 AM
gimark's Avatar
That looks almost identical to my setup first time I put it together. Only difference is I used black tubing (which i now regret).
You could use NCIX.com - Buy Ek Water Blocks EK-D5 X-TOP Version 2 Custom Pump Top for D5 & MCP655 Pumps G1/4 - 3830046995077 In Canada. to allow you to put that pump in the lower area.
Old November 23, 2009, 09:01 AM
If you use bitspower fittings on the t3 you need thicker o-rings. The included ghost compression fittings on my t3 worked fine albeit they were a bit of a pia to work with.
If your case has little tabs inbetween the drive bays like the haf you will need to remove or bend them out of the way inorder for the t3 to fit flush.
Also make sure that the included metal plugs for the front of the t3 aren't made of steel like mine were.
Old November 23, 2009, 09:23 AM
Dazmode's Avatar
Looking on the picture, there is tons of pace for round EK reservoir right from mobo. I second 655 x-top suggestion. Better flexibility, quiter and more performance. What else to ask?
Orange Build: Final Video
HTPC Build: Final Video
Old November 23, 2009, 12:17 PM
I second that, the T3 is the best thing you could use. An Ek X-Top is good, but then again you will still be running tubes, which wouldn't be much different from your current setup..
However if you use a T3, you're pump and res is at the same spot, which saves you a little tubing.. Plus with the T3, future use, I believe it accommodate more than one loop.
What do u think about this WC setup Grosjambon Water Cooling 6 October 19, 2009 03:32 PM
[WTB] LOOKING FOR A WC SETUP _dangtx_ Buy/Sell & Trade 10 August 14, 2009 12:15 PM
[WTT] My LGA775 DDR3 setup for your AM2+/AM3 setup Realityshift Buy/Sell & Trade 2 April 12, 2009 05:17 PM
Need a setup ChuckleBrother HTPC Systems & Software 2 August 21, 2008 09:01 PM
WC setup Dark Water Cooling 24 January 14, 2008 05:02 PM
