  #21 (permalink)
Old November 24, 2009, 06:41 PM
How do you fill the T3? Is it super convenient since it's a drive bay?
  #22 (permalink)
Old November 24, 2009, 07:51 PM
This is the major downside of the t3, the best way to fill and bleed this thing is with the case on its back.
  #23 (permalink)
Old November 27, 2009, 12:49 AM
aviduser's Avatar
Yeh, the filling and bleeding is a bit of a p.i.t.a. Especially if you have a rad mounted on the back of the case. But once its all said and done it isn't too painful.
Definitely use teflon tape on whatever fittings you use. I'm kinda dissapointed it didn't come with instructions. I had issues with mine leaking around the pump o-ring and the ghost fittings. Put the stock o-ring in and some barbs with teflon tape, and its been good so far. Does make me a little nervous having a pump/res combo sitting right above my hdd's. But that comes with the territory of wc'ing.
I5 4670K 4.4ghz - Gtx 780 Amp - 2x4 Corsair Vengeance - MSI z87-g43 - Tx 850w - Asus pbq278q
  #24 (permalink)
Old November 27, 2009, 02:44 PM
I noticed you have the same plugs in the front of your t3 as I did. You should check to make sure they're not steel, mine were and were already rusting badly after 2 weeks.
  #25 (permalink)
Old November 27, 2009, 06:38 PM
Ooh, T3 doesn't look so good no more:
Any Black Firday WC stuff? - Overclock.net - Overclocking.net
Any other option? I personally hate the Micros Res V2, so inconvenient, no place to put it.
Thanks.
  #26 (permalink)
Old November 27, 2009, 06:40 PM
Dazmode's Avatar
You can look into EK-MultiRes - very flexible for connectivity and good looking too. T3 is rather ugly IMHO.
Orange Build: Final Video
HTPC Build: Final Video
  #27 (permalink)
Old December 1, 2009, 09:40 PM
Is the T3 really as bad as OCN says it is?
  #28 (permalink)
Old December 1, 2009, 09:52 PM
AmuseMe's Avatar
As far as I am aware, the T3 is not very good. On more than one occasion it has been reported to have little bubbles in the acrylic and that lead to cracks for a few people, which in turn caused huge leaks. Also, I can say I have heard many more negative responses than positive ones.
  #29 (permalink)
Old December 1, 2009, 10:13 PM
Its been so bad that Primochill is bringing all the tooling equipment from China to the US to address the poor quality control.
heatware
ebay
  #30 (permalink)
Old December 2, 2009, 08:07 PM
aw that sucks, it's such a good idea.
I hope one day something similar to the T3 comes *hopes*
What do u think about this WC setup Grosjambon Water Cooling 6 October 19, 2009 03:32 PM
[WTB] LOOKING FOR A WC SETUP _dangtx_ Buy/Sell & Trade 10 August 14, 2009 12:15 PM
[WTT] My LGA775 DDR3 setup for your AM2+/AM3 setup Realityshift Buy/Sell & Trade 2 April 12, 2009 05:17 PM
Need a setup ChuckleBrother HTPC Systems & Software 2 August 21, 2008 09:01 PM
WC setup Dark Water Cooling 24 January 14, 2008 06:02 PM
