Dtek Fusion V1 LGA1366 Hold Down Adapter? Does such a thing exist? Where to get one? |
Here. Getting hard to find, actually. It will fit both the V1 and V2 versions of the block, although you'll want to be careful with the V1 - there are potential clearance issues with the screws attaching the bracket to the underside of the block. Sometimes they'll stick down too far and they'll hit the IHS instead of the actual cooling surface, so you'll need to grind the bolts down a little. |
I know they have one that works for the v2, which should work for v1.. But it looks like almost everywhere is out of stock (including US, as far as I checked).. FuZion Intel Core i7 (LGA1366) Pro-Mount Set Straight from d-tek maybe.. Or post a WTB thread, i'm sure someone has one sitting.. edit: MpG beat me to it.. darn... although I checked jab-tech too, out of stock boss. |
Ah, thanks guys. Will post a WTB thread, but the rush I am in, this doesnt seem plausible. Thanks though! |
Only if the hold down plate for the i7 mounting wasn't a little wider, modification could have been possible.. Recently purchased an apogee gtz that came with i7 mounting, off course I don't need it.. I'm sure you could use the back plate, but the hold down plate, probably no dice.. Good Luck getting one Paul. |
Thanks Miggs |
| All times are GMT -7. The time now is 11:08 PM. |
