  #61 (permalink)
Old November 15, 2009, 09:45 AM
AmuseMe's Avatar
Originally Posted by brewer265@ View Post
If you use barbs with lots of threads in the koolance block it can block flow from getting into the block because of how thin it is. Anywhere else in your loop the EKs wont hurt anything.
Really Koolance... Come on you crooks! Making people using only your fittings
Wait... does that mean my BitsPowers fitting wont work??? That I complained about, and did not totally just buy some
  #62 (permalink)
Old November 15, 2009, 09:49 AM
Yes bitspower will work on koolance blocks. I used them on the one koolance gpu block i had.
heatware
ebay
  #63 (permalink)
Old November 15, 2009, 10:29 AM
MpG's Avatar
MpG MpG is offline
Heh, no conspiracy (this time). They may have changed more recently, but EK's barbs (and some other brands) for the longest time had fairly long threads, and when you screwed them into the copper side of some full-cover waterblocks, they could actually screw in far enough to block flow from going down into the block. It started about the same time companies worked on making their GPU full-cover blocks as skinny as possible to make them single-slot width and save on copper costs.
Other than that, the barbs are just fine anywhere, and they shouldn't have issues on the acetal/acrylic sides of the full-cover GPU blocks either. You can usually eyeball them and compare them to see if that's going to be an issue. BP's stuff has short threads, so you won't have issues there.
  #64 (permalink)
Old November 15, 2009, 10:35 AM
HaDeS
Guest
Posts: n/a
you need to bang and tilt and bang and fill and pump and bang and... until you get the loop full and running. that 420 rad is gonna use a ton of water and takes longer to fill up than most would thing. You've basically got a 720 rad? with the duals. That's a lot of water mate...
  #65 (permalink)
Old November 15, 2009, 11:23 AM
AmuseMe's Avatar
It was definitly the EK Barbs. I replaced them with some shorter Swiftech ones, and DONE! IT FLOWS!!!
Now I fill it with only distilled, wash out and blue Feser Fluid, and leak test with clean distilled water untill my BP ones come in!
  #66 (permalink)
Old November 15, 2009, 11:25 AM
Nice , just a suspicion i had , i rembered a thread a long time ago at xs with somebody having the same problem.
heatware
ebay
  #67 (permalink)
Old November 15, 2009, 11:39 AM
AmuseMe's Avatar
That Laing 5 pump and aftermarket EK top really flow... Wow... (Im use to a Swiftech Apogee Drive lol!)
  #68 (permalink)
Old November 15, 2009, 12:07 PM
Congrats man, I've been watching this thread and couldn't come up with any useful answer. All I know is I would've been way more frustrated than you sound in your videos!
  #69 (permalink)
Old November 15, 2009, 05:10 PM
Lima's Avatar
@ AmuseMe
Congrats, I've been watching too.
@ brewer265@
That was a nice bit of info there, nice one!
  #70 (permalink)
Old November 15, 2009, 09:27 PM
Dazmode's Avatar
Interesting... did not think about that at all.
Congrats on resolution :)
Orange Build: Final Video
HTPC Build: Final Video
Loop help Lpfan4ever Water Cooling 12 September 22, 2009 06:22 PM
tri-fire loop, filling/bleeding vinister Water Cooling 17 May 18, 2008 10:30 PM
Free Space In Case Needs Filling ChuckleBrother Cases 9 May 14, 2008 04:37 PM
filling, bleeding and testing new loop magictorch Water Cooling 25 April 10, 2008 02:35 PM
My Soon-To-Be loop Kopi Water Cooling 5 October 23, 2007 12:49 PM
