OK, so it looks like you have fluid both before (and in the res) and after the pump, so lets guess the pump is full. That 480 is going to take a while to fill, so id run that for a while. As long as the res had fluid level, and the pump doesnt sound like an angry wasp is inside, it should be a nice quiet rumble. My pump is suspended, and hardly makes a noise as the vibrations dont resinate through the case.
How long have you run it for? The water pushed into the 480 should follow through the rest of the lines and push out the air easily!
Last question... is the 480 blocked at all????
I run 2x240 rads, MB CPU and 2 SLI blocks on a little MCP 355, that pump of yours should pump that air out quick once its filled the 480?
__________________ AJ's Gamer, Finally finished! Win 7 64 bit / Antec 1200 / E8400 EK Supreme LT / Xfx 780i SLI / Mushkin 6Gb EM2-6400 - Corsair 3 Fan Cooler / Corsair HX 1000W / 2xSeagate Sata II - Raid 0 / 1xSeagate Sata II - Storage and backup / 2xEVGA GTX285 1Gb- SLI Ek blocks / 2x240 Swiftech Rad, Full Push-Pull / MCP355 w/ Petra Top / Micro Res / Danger Den Fillport Blue / Matrox Digital TH2G / 3xSamsung 226BW's |
