Old September 15, 2007, 07:23 PM
Supergrover's Avatar
Well I decieded to not go with a kit, just ordered this:
Thermochill Pa 120.2 Dual 120MM Fan Water Cooling Radiator *No Barbs*
Swiftech Smartcoils 625 Blue
Magicool Thermochill Mounting Screws 3.5 X 40MM (4 Screws) x2
Thermochill FG120.2 Fan Grill for PA120.2 Radiator
Danger Den 1/2IN Polyethylene Barb Fittings 3/8 NPT (Pair)
NCIX is out of
Thermochill 1/2IN Chrome Plated Barb Fitting G3/8 Threads *Single Barb* for now
Awaiting Order:
Tubing: So what do I want here say 5' of Tygon R-3603 1/2IN ID 3/4IN OD Tubing 5 Feet
for the bends and what else is good for straight runs?
WB: Pretty sure about going with the Fuzion but is it worth it to go with Water Accelerator Nozzle Kit for D-TEK Fuzion CPU Block
Pump: Swiftech MCP655 12V Industrial Water Cooling Pump 1/2IN Barbs
Reservoir: Still up in the air about eithier Swiftech MCRES-MICRO Clear HI-FLOW Water Cooling Reservoir 3/8IN & 1/2IN Barb Fittings or Ek Water Blocks Ek Multioption Res 250 REV.2 G1/4
leaning towards the EK.
Anything I am missing besides clamps and hydrx?
lol And fans
R.I.P.
Old September 15, 2007, 07:32 PM
sswilson's Avatar
Heh.... I was just about to say "fans"...... :)
I also like the look of the EK res, but ultimately cheaped out and went with the swiftech. Have a good look at the orientation of the barbs on each one and visualize how it's going to fit into the loop once it's in your case.
That fan grill is a pretty sweet looking piece of kit!!!!
Glad to see that you're finally coming over to the dark side.... do you think Miso's been slipping something into the water supply??? :)
Old September 15, 2007, 07:39 PM
Definitely
No after the Water is done, a new desk, then it's hopefully Quad time
For me it going to be a whole new build, Mobo/CPU/RAM/GFXcard and am tired of limits of air,plus it all swaps over
R.I.P.
Old September 15, 2007, 07:47 PM
3.0charlie's Avatar
Don't go cheap on the Tygon - nothing worse than missing a few inches to close the loop... figure out your routing, and add 25% in lenght. That's what I do.
suggestion for a intel build ebdoradz CPU's and Motherboards 9 February 13, 2008 09:43 AM
Suggestion qwerty Suggestions & Feedback 5 October 16, 2007 02:22 PM
ram suggestion skyline510 RAM 9 September 15, 2007 09:55 AM
First build. l0ck Troubleshooting 15 July 25, 2007 04:24 AM
