Old September 7, 2007, 07:56 PM
Patriote's Avatar
Oh so you are getting a dual 120mm rad, right ? Cuzz a single 120 won't cut it for you sswilson. I'd get nothing else than a MCR220 and if you have the space, for 2$ more you can get the MCR320... Might want to get a rad-box from Swiftech to hook the rad behind the case.
- Asus P8Z68-V PRO
- Intel I5 2500k @ 4.5Ghz
- Asus Geforce 580GTX DirectCUII Fermi
- 16GB Corsair Vengeance Low Profile
- Ultra X3 1000 Watt
- Asus Xonar DX 7.1 \ Klipsch Promedia 2.1 THX
- Corsair Vengeance 1300 Gaming Headset
- Crucial M4 SSD 128GB \ WD Caviar Black 1TB
- CoolerMaster 690II Advanced
- Dell UltraSharp 24''
- Noctua NH-D14
Old September 7, 2007, 08:23 PM
sswilson's Avatar
Heh......
Easy way to bump my $160 order up to $200 before taxes + shipping and handling... :)
wonder if I can come up with a way to mount that on top without the radbox.....
Need to find some form of bolt stock with a screw on the end that would fit into the rad case.... (like the brass hooks you can buy to screw into the wall, but with bolt stock attached to the screw rather than a hook.... :) ).
The 240 would fit better... but I'd hate to miss out on an extra 120 worth of cooling for $2..... :)
Old September 7, 2007, 09:33 PM
Patriote's Avatar
Originally Posted by sswilson View Post
Heh......
Good way of thinking. Me looking forward for this build. BTW: Home Depot, Rona and any other kinda like store will do for the screws.
- Asus P8Z68-V PRO
- Noctua NH-D14
Old September 14, 2007, 03:17 PM
sswilson's Avatar
Placed my order this evening.......
D-TEK Customs 1/2IN G1/4 Chrome High Flow Barb Fittings (Pair) X2
Clearflex 60 Tubing 1/2IN ID 7/8IN OD 10 Feet
Pts Petra PT_NUKE Concentrated Biocide Water Additive for Water COOLING(10ML)
Swiftech MCP655 12V Industrial Water Cooling Pump 1/2IN Barbs
Swiftech MCR320 Quiet Power Water Cooling Radiator Black G1/4 Threaded
Swiftech MCRES-MICRO Clear HI-FLOW Water Cooling Reservoir 3/8IN & 1/2IN Barb Fittings
Swiftech Smartcoils 625 Blue X2
Yate Loon D12BL-12 120MM Quiet Cooling Fan 1200RPM 45CFM 24DB 3PIN & 4PIN Ball Bearing OEM X3
Apparently I got my order for the Yate Loons in just before the price went back up........ :)
Now it's time for the waiting and planning.
It's going to be another top mount with the fitting end of the rad hanging slightly over the back of the case to allow the tubing to go straight down (might look into a 90 deg. fitting to bring it straight into the back....).
I've got somebody who's going to bend some SS stock for me (reverse the top and bottom of a "Z" for general shape) to raise and mount to the top of the case. I figure 5 pieces of stock on each side (first 5 fan screw holes) will give me plenty of stability / support.
I'm digging through my old audio gear for a suitable volume control which should be able to handle 3 or 4 fans in parallel.
On top of that.... I've been sitting on a bunch of flush mount windows kits for the last 6 months so my lian-li is going to get top and side flush mount windows along with the 4 UV Leds (5 per) I ordered when I picked up my Water Block last month.
Sooooooo........ like I said.... not much to do now but wait....... :)
Old September 14, 2007, 07:05 PM
Wankerfx's Avatar
That is quite the build! Post pictures when it's ready.
[ER]
Old September 14, 2007, 08:27 PM
Patriote's Avatar
Nice nice! Have fun!
On a side note, check my next build ;) Looking for some inputs from you guys on my next build! - XtremeSystems Forums
- Asus P8Z68-V PRO
- Noctua NH-D14
Old September 18, 2007, 07:09 PM
sswilson's Avatar
Heh.....
Got the dreaded "your order has partially shipped, backordered items will be shipped at no cost to you when they become available" e-mail.......
Thinking the worst, I went over the shipping manifest and discovered that the 1 backordered item is the second set of smartcoils I ordered just to be safe.......... :)
Yahoo!!!!! So now we just wait for Puralotor ground to get this thing from one end of the country to the other...... :)
Old September 19, 2007, 03:00 PM
cdn_Madrach's Avatar
Heh.....
Ahh...the stress of ordering parts then waiting to see if they ship it all and the most difficult thing......waiting for them to arrive. woot aint it great
Intel e8400
Asus P5q pro
Mushkin Redline 4gb
Silverstone Strider 1kw modular
4870x2
Ocz Vendetta 2
Top deck Tech Station
Samsung dvd
  #19 (permalink)
Old September 19, 2007, 03:05 PM
Supergrover's Avatar
Heh.....
I hate you willy!
I ordered the same smartcoils from ncix just after you, they showed in stock, but seeing as my order hasnt shipped I am assuming this is the reason why.
Damn and ncix is out of fuzion cpu WB's too, I was going to order the rest of my parts this sat, guess I will be waiting until more come in
R.I.P.
New build suggestions. taal CPU's and Motherboards 1 February 4, 2008 11:58 PM
First build - looking for suggestions (am noob) Nimbus CPU's and Motherboards 17 July 17, 2007 01:35 PM
My build, suggestions? Magice CPU's and Motherboards 7 July 16, 2007 10:52 PM
first build, suggestions help? mgp141 CPU's and Motherboards 5 March 30, 2007 03:24 PM
Suggestions On New Build BALISTX CPU's and Motherboards 14 February 14, 2007 01:10 AM
