Old November 4, 2009, 06:57 AM
rai_polo's Avatar
Lol.. yeah, in a 922 I think the method I outlined would be best, or at least really good.
Heatware
Old November 4, 2009, 11:21 AM
gingerbee's Avatar
ya i thought he had a 932 not a 922 mis-read. and the monsta does fit in the top of the 932 I almost bought one so i measured it all up. off of daz. just running so many rads to me is pointless a good double will do my i7
Old November 4, 2009, 12:32 PM
rai_polo's Avatar
Good double rad should be enough for just the cpu. But if he adds a video card or chipsets he gonna want more.
Heatware
Old November 4, 2009, 12:36 PM
gingerbee's Avatar
a double rad is good for a lot more then just cpu. c2d not i7 hell i could do the setup i am running on a dual rad just got a good deal on a triple so why not
EDIT i ran a q6600@3.6 on a single temps were great and have run many a quad on a single rad so why would he need so many rads it's water
Old November 5, 2009, 03:29 AM
HaDeS
Guest
Posts: n/a
If he wants to OC extreme he's gonna need a dual rad in my honest opinion. IC7 is a waste of time and effort the pay off simply isn't worth it.. if you are worried about a degree or 2 lap the cpu and the heat sink. I've learned that plain jane thermal paste works just fine and doesn't conduct electricity like arctic silver and you can apply it with a modeling paint brush with NO effort. You could purchase a life time supply of regular old non conducting white thermal paste for the same cost as one small tube of ic7 or silver. If he absolutely plans to water cool his entire rig he should consider getting a triple rad or double up on the mcr220's
The mcr 220 in a push pull would probably do you just fine and if it's not enough you can stack those rads if I'm thinking of the right ones. That Apogee looks sexy.
[FS] Intel Q6600 3.8GHz Stable, Asus Mobo, Geforce 8800 gtx, HDD, Watercooling donkon Buy/Sell & Trade 8 June 17, 2009 05:40 PM
Expect more calls Eagle Eye Off Topic 30 January 26, 2009 07:52 PM
Is my O/C (temps and volts) safe for 24/7 folding? divertiti Overclocking, Tweaking and Benchmarking 10 January 5, 2009 07:45 PM
What should I expect? Jesterhead New Builds 4 October 26, 2008 05:49 AM
Didnít expect this DK2 Troubleshooting 16 August 6, 2008 08:00 PM
