Old November 3, 2009, 02:46 AM
sswilson's Avatar
A little late to the game but ++ for the Enzotech heatsinks. If the airflow in your case is lacking you can pair them with one of the spotcoolers to wick away the heat.
A word of warning on the Enzotech's though.... it can be addictive. If you decide to go that route, you may want to pick up a roll of double sided heat tape at the same time as you'll be putting them on everthing that's got a flat surface...... ;) (No... contrary to popular belief, the cat does not need extra cooling................).
Rad help JMCD Water Cooling 9 June 24, 2009 02:37 PM
Need help with my dual rad in a single loop jusdrink Water Cooling 33 June 20, 2009 03:43 AM
2X120mm rad dual gpu+cpu loop nckid4u Water Cooling 19 May 12, 2009 05:05 AM
Single rad $$$ > Dual rad $$$ why? frosty Water Cooling 9 July 16, 2008 03:39 PM
2 x MCR120 vs Dual Rad enaberif Water Cooling 2 June 6, 2008 04:52 AM
