Old October 19, 2009, 03:07 PM
BrokenHalo83's Avatar
Default Help deciding which pump
Like the title says. As this is my first attempt at water cooling, i'm looking to get some advice as to which pump i should be using. I'm using 1'2" ID tubing. Using a EVGA X58 vanilla board
HK 3.0LT
Bitspower mosfet block
Bitspower NB/SB block
Feser triple rad
May cool 2 GTX 275's on a separate loop. TIA
Main system down....
Running a craptastic Compaq
Old October 19, 2009, 03:22 PM
if it was me i would get my self a D5
Old October 19, 2009, 04:17 PM
gingerbee's Avatar
mcp 355 or 655 take ether one. Have both and there both great performers
Old October 19, 2009, 05:11 PM
MpG's Avatar
MpG MpG is offline
That's not a particularly restrictive loop - just about any pump will work fine. Another good option might be the recently released EK DCP 4.0 (basically the CPX-Pro pump rebadged). It's a very strong contender, and doesn't need an aftermarket top, and much better priced.
Old October 27, 2009, 09:37 PM
biff's Avatar
FWIW I just replaced my CPX-1's with CPX-Pro's and I'm not so happy with their noise. Mind you I wasn't happy with the CPX-1's at first either for the same reason, but after ~1 month of use the CPX-1's were DEAD silent so I'm reserving judgement on the Pro's to see if things change.
Q6600 @ 3.83GHz w/ D-Tek Fusion
Asus P5Q-PRO
2x 2GB PC8000 Mushkin Redlines @ 1020MHz w/5-5-5-12 timings
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Cooler Master Cosmos on water
Old October 27, 2009, 10:02 PM
Lpfan4ever's Avatar
Hmm, I've never noticed mine being noisy. So long as it's on a piece of foam I can't hear it. That said however, 19 fans tends to drown out most noises, soo
Originally Posted by encorp
Code:
<firebane> slightly used
Old October 27, 2009, 10:11 PM
MCP655 (D5) pump..
Old October 27, 2009, 10:20 PM
MpG's Avatar
MpG MpG is offline
Odd. I had something of a grinding noise at first with my DB-1, but they went away in a few days. My own CPX-Pro was quiet from the very start. I would vibrate if you had it touching something else solid, but as long as it was sitting on something soft like gel/foam/felt, it was easily as good as any of my DDC's.
Need Help deciding PS3 or Xbox 360 AA93 Gaming 39 May 15, 2009 12:47 PM
I need help deciding. encorp CPU's and Motherboards 16 March 13, 2009 12:07 AM
Deciding between 3 sammsung monitors slntdth93 Display Units 2 October 19, 2008 11:12 AM
Need Help in Deciding Swiftech or Thermochill Dashock Water Cooling 3 June 19, 2008 04:15 PM
Deciding on a Case BALISTX Cases 6 May 19, 2007 09:55 AM
