Old October 17, 2009, 12:08 PM
Default What do u think about this WC setup
hi, here is the setup:
Tubing : Feser Tube Active UV Hose - 1/2" ID (3/4"OD) Anti-Kink Tubing - UV Red 10feet 27,50dollars ( i toook them because review say that its more red when uv than other tubing marks.
FAN : Yate Loon 120mm x 25mm Fan (D12SM-12) (1650 rpm 10%+/-) x3 20,78 dollars
Total cost 70,38 from frozen cpu. (22dollars of SHIPIING / hate canada)
Swiftech MCP655 12v DC Pump - with Speed Controller : 78$
Swiftech MCR320-QP Quiet Power 3X120mm - Black : 50$
EK Waterblocks EK-Multioption RES 150 rev.2 : 42$
HEATKILLER® CPU Rev3.0 754/939/AM2 85$
Petra'sTech PT_Nuke -PHN Concentrated Biocide (10mL) : 3$
Bitspower 1/2in. Compression Fittings for 3/4in. OD Tubing x4 : 20$
Bitspower Shining Silver Rotary 45 with 1/2in. ID Barb - # BP-45R2I : 20$
Total Cost 297$ SHIPING : 31$ = 330$
330$ + 70$ = 400dollars approxi.
Any suggestion - better piece for lower or anything else feel free to post ;)
Old October 17, 2009, 04:17 PM
Dazmode's Avatar
Except HK, you can get everything in Canada. I'm sure NCIX has fans for less money, then you pay from Frozen CPU.
Orange Build: Final Video
HTPC Build: Final Video
Old October 17, 2009, 04:34 PM
Pretty good list.. As dazmode said.. you can get everything except the HK block from canada.. ncix pretty good for most other stuff, try dazmode.com too (^^ :p), pretty good stuff on there too (he's canadian, thank god)..
Also about the HK block, this Koolance block is pretty good and seriously for the price he's selling at, I would go for it with your eyes closed, excellent price..Koolance CPU-350AC (Acrylic)
All to all, you're gonna save a lot on shipping getting it from Canada..
Old October 17, 2009, 06:44 PM
hmmm i will see do u have any site with lowest shippppppiiiiinnnnngggg. I will try ncix but are they another site? -
Old October 17, 2009, 06:52 PM
i can't find fan at 1650 rpm +- on ncix lower than 6,99 $.
Old October 17, 2009, 11:53 PM
CanadaRox's Avatar
I'd suggest checking some Canadian stores such as NCIX.com - Canada's Premier Computer Store - Great Technology, Service and Selection. or Canada Best Water Cooling Store for the parts (if you use NCIX, be sure to pricematch using PriceCanada.com: Search. Compare. Buy. - Canadian Online Shopping Search and Comparison!). I'd suggest checking our Performance-PCs.com, ... sleeve it and they will come for the parts from the US as they generally have cheaper prices for them. You could also check Petra's Tech Shop or Sidewinder Computers - Supplier of High Quality PC Modding and Cooling parts for some of the parts. They are both located in the States and have decent prices and great service, but I don't think either has the HK3.0.
Project: Black and White
Old October 19, 2009, 03:32 PM
i agree look in canada first but its a real nice list
[WTT] My LGA775 DDR3 setup for your AM2+/AM3 setup Realityshift Buy/Sell & Trade 2 April 12, 2009 05:17 PM
Need a setup ChuckleBrother HTPC Systems & Software 2 August 21, 2008 09:01 PM
WC setup Dark Water Cooling 24 January 14, 2008 05:02 PM
Help with WC setup Cptn Vortex Water Cooling 6 October 3, 2007 12:18 PM
how does this setup look? moditir Water Cooling 24 August 26, 2007 09:41 AM
