Old October 15, 2009, 07:45 PM
Dazmode's Avatar
Originally Posted by vinzend View Post
im planning to buy Cosmos S too so i can fit it in.. currently using antec 1200 which cant fit in for sure..
I believe you can fit triple in drive cage area and still have 1 or 2 CD slots.
and about the reservoir, he said t-line is better in throwing the air away
Incorrect. Process called bleeding.
Orange Build: Final Video
HTPC Build: Final Video
iono, it's like a combo.. i havent done any bargain.. i think i can lower the price to $220.. (hope so :D)
what are ur temps?
yea probly i'll keep 1 for next time if i get addicted or w/e.. :D
yea i'll try bargaining.. hope can lower it to $220.. :D
and about the reservoir, he said t-line is better in throwing the air away or something like that.. :confused:
So, what should i do then?
If he throws some decent barbs in, lowers his price and/or adds fans (BTW if you check Direct Canada they should have two MCR320's that I returned two weeks ago at an open box price) and you trust the guy, go for it. You have to start somewhere. It's going to be a learning experience to say the least and you will probably have questions and need parts even after you think you have it all :) For example buying fans can be an experience on its own, I've got at least 12 extra fans laying around after building my latest rig :) I originally wanted what I consider to be the best (Gentle Typhoon 1850 rpm) couldn't find them anywhere so I tested a few different configurations. Then one day found a Canadian distributor that had some in stock
One of things you will have to do is spend a LOT of time reading reviews, builds, etc. on the various water cooling forums.
I'm oced at 4.2Mhz @ 1.38v, idle temp is 37c full load (running Prime95 or OCCT )temp is 67-70c. You will never see those high temps in every day use.
Old October 15, 2009, 07:48 PM
Originally Posted by SugarJ View Post
At 4.0 GHZ I was 42 idle and 61 load. $220 would be more in line for used equipment. And you'll love the Cosmos, I had one before I moved to the TJ-07.
Get a res, what he said about the T-line is straight BS.
yea i prefer res to actually.. ok so what i should do are :
buy 1 rad, pump, gtz, tubes from him and reservoir, coolant from store?
is there anything to do to make it load under 60?
Old October 15, 2009, 07:53 PM
oh soo take the bays off? and put the rad there?
i want the san ace but cant find it in canada.. :(
what lying fans do u have?
yea i have dealt with him once.. so it should be fine dealing with him again..
Old October 15, 2009, 08:01 PM
Dazmode's Avatar
There are San Aces in Canada. You just didn't look hard.
Check this:
YouTube - How to Fix Water Cooling Radiator Inside of the Case - LCWB#8
Old October 15, 2009, 08:14 PM
Check this:
oh wow, cool.. ok, so from what he is offering me, which should i take and which should not?
then what else to buy in stores?
Old October 15, 2009, 08:34 PM
Dazmode's Avatar
I'd say skip one radiator.... the rest worth no more then $150.
Old October 15, 2009, 09:30 PM
I'd also do as Daze suggests here. Besides you will need the extra cash for other parts :)
what are ur temps?
  #19 (permalink)
Old October 16, 2009, 06:53 PM
Reservoir:
XSPC Premium Acrylic Reservoir for Laing DDC
Swiftech MCRES-MICRO REV2 Clear HI-FLOW Water Cooling Reservoir
which 1?
  #20 (permalink)
Old October 16, 2009, 07:30 PM
I would go with the swiftech micro-res. Best bang for the buck res and easy to bleed all the air out of your loop with.
heatware
ebay
noob help for i7-860 OC Sandro_Bit Overclocking, Tweaking and Benchmarking 2 September 24, 2009 01:40 PM
help a noob out jtf2 Audio 40 August 27, 2009 09:54 PM
[WTB] I am a noob and i need some help :D eltiti55555 Buy/Sell & Trade 16 March 9, 2009 01:02 PM
Complete Noob Needs Help Trevor Water Cooling 10 February 21, 2009 06:18 PM
Noob question... shayan288 RAM 1 January 8, 2009 04:13 PM
