Old August 29, 2007, 02:05 AM
Hitikiro's Avatar
Default Modding Yate Loon DS12L
Would anyone know if it is possible to just literally cut off the 4 pin molex, which is attached to the fan, and still have the 3 pin molex be fuctional?
Old August 29, 2007, 02:30 AM
sswilson's Avatar
Judging from the way it looks like it's wired up, I don't see why not, although you'd be better served to undo the pins from the 3 pin and do it inside the connector than just cutting as it sits. (Do only one fan first though just in case.... :) ).
Old August 29, 2007, 09:49 AM
JayDee
Guest
Posts: n/a
I just got 2 Yate Loons (from NCIX hidden sale) and I plan to cut off the molex and splice the wires.
Old August 29, 2007, 09:53 AM
Yes you can cut off the molex as the wires for it just run into the plug for the fan. Molex is for power from the PSU , 3 pin for motherboard.
Keyboard modding chibi_man Peripherals 2 November 8, 2007 05:25 PM
X-Fi modding. turtletrax Audio 8 October 30, 2007 11:19 AM
Not Quite Modding - Tools Related Drew Cases 2 September 30, 2007 08:27 AM
Plexiglass Modding guide from Modders Inc Babrbarossa Reviews & Articles from the Web 5 May 14, 2007 07:23 PM
