Old October 11, 2009, 10:00 PM
Default Blocks for GTX 285?
Hey guys, I'm in the process of putting together my Rig and am going WC for a few things including my GPU's. My problem tho, lies in the fact my Blocks are not full cover, so i need something to cool the rest of the card. what do you recommend? passive, active or WC dosen't bother me unless there is a significant performance difference. ( I do plan to OC them) I am using a pair of D-Tek FuZion GFX 2's, but dont like the coolers that go with the block from d-tek. what are my options?
Death to Apple
Old October 12, 2009, 04:43 AM
Dazmode's Avatar
If you don't use fullcover block, then you need to use self adhesive heatsinks in several areas. For example MC14 and MC21 from Swiftech. You might want to blowair on them as well.
Orange Build: Final Video
HTPC Build: Final Video
Old October 12, 2009, 08:56 AM
I fugured. Just wondering if there was a block i could add to the loop to cool them. but owell.
Death to Apple
Old October 12, 2009, 09:10 AM
Dazmode's Avatar
I have never heard about separate GPU block for VRMs and such...
Old October 12, 2009, 01:32 PM
I have seen them once. but for the 8800 seris only, i think...
Death to Apple
Old October 12, 2009, 02:45 PM
SugarJ's Avatar
The unisinks are a much better solution IMHO. I had 32 enzotech sinks on the ram chips and vrms (Rev 2 GTX285) and was still having the vrm's overheat. You need a big HS to dissipate the heat. They ain't pretty, but they work.
[FS] HeatKiller 285 and 295 GPU blocks Liu Kang Buy/Sell & Trade 9 July 28, 2009 04:09 PM
The GTX 285 2gb vs. GTX 295 vs. GTX 350 (rumour) shayan288 Video Cards 9 May 25, 2009 12:29 PM
Is it worth the trouble for stepping up EVGA GTX 260 Core 216SC to GTX 285? appplejack Video Cards 4 February 14, 2009 05:05 PM
[Checking interest] FS: GTX 260 / GTX 280 XSPC Full Cover water blocks S_G Buy/Sell & Trade 4 November 15, 2008 04:34 PM
