Old October 9, 2009, 10:54 PM
AmuseMe's Avatar
Default The Loop - General Questions
A few quick watercooling questions
1.) I was told that the Swiftech MCP-355 with and Ek-DDC X-Top Waterblock (http://www.dazmode.com/store/index.php?main_page=product_info&cPath=71&products _id=376) better than the Swiftech MCP-655? Just want some more confirmation than from one person.
2.) Also, my second question. I know that it doesn't matter the configuration of the water cooling loop. However, after reading some posts I became aware that after the water passes through the pump, there is a little bit of heat transfered - not enough to matter, but on a budget build, every bit helps. So what do you think of this
Resivoir --> Pump --> 120.4 Radiator --> CPU --> NB --> 120.2 --> 4870X2 --> Resivoir
Thanks everyone!
Old October 9, 2009, 11:40 PM
SugarJ's Avatar
1. I don't know
2. That makes the water at it's coldest before traveling over the blocks. It's how I try to set my loops up. It doesn't make a big difference though.
Old October 9, 2009, 11:50 PM
the 355 and the 655 are both good pumps but I'm going to say he's possibly comparing the 355 to the non-adjustable 655.
The adjustable 655 can and has outshined the 355.
Old October 9, 2009, 11:52 PM
bottle's Avatar
I believe the MCP655 has a higher flow rate while the MCP355 has better head pressure. With a top (I would recommend the XSPC Res/ Top for around $30) it sacrifices some head pressure for flow rate, though I could be wrong.
That being said, the MCP355's noise is around the 4-5 speed range of the MCP655, which is unbearable for me. I actually keep my pump at speed 1.
Old October 10, 2009, 12:04 AM
AmuseMe's Avatar
Hm... Again, more mixed answers lol. Well, I wont be ordering my pump for another week atleast, so Ill get some research down/ keep checking the forums.
How does this look for the loop?
Res > Pump > 120.4 Rad > CPU > NB > 120.2 > GPU > Res
Old October 10, 2009, 12:24 AM
For that loop I'd definitely recommend a 655 adjustable.
The 355 is a good pump but as someone said they can run a bit louder.
Old October 10, 2009, 02:53 AM
Yes I would agree, spend the extra few bucks and get an adjustable MCP655, it's one powerful pump that can withhold anything..
An MCP355 with a top is real good too, let's just say on a setup similar to yours when the topped MCP355 starts giving up, that's where the MCP655 comes into play.. Remember they are 2 versions of the 655, get the adjustable..
Old October 10, 2009, 09:15 AM
AmuseMe's Avatar
I ordered this one from NCIX (NCIX.com - Buy Swiftech MCP655 12V Industrial Water Cooling Pump 1/2IN Barbs - MCP655 In Canada.) It was cheaper than the one with "*WITHOUT SPEED CONTROLER*"
Old October 10, 2009, 12:06 PM
gingerbee's Avatar
you won't be disappointed. I have both pumps and can tell you the only difference i can see is with the bigger the loop the 655 performance is just a little bit better not really a big deal so
Old October 10, 2009, 12:19 PM
Did you price match... the one with speed controller costs the same when price matched.. c'mon now..
Some general information m0pelley99 Water Cooling 9 July 8, 2009 08:00 PM
I7 OC General questions n-sanity Overclocking, Tweaking and Benchmarking 8 June 21, 2009 08:08 AM
General folding hardware questions.... Perineum HardwareCanucks F@H Team 5 May 12, 2009 08:21 PM
Soups loop questions thread. Supergrover Water Cooling 6 November 8, 2008 08:14 AM
General forum questions sswilson Suggestions & Feedback 2 December 27, 2006 06:46 AM
