Old October 9, 2009, 08:27 PM
Talking Waterblock for HD5870?
I know there is an EK one, an Aquacomputer one, and a koolance one.
Which one is best?
Also, would a triple rad suffice for an i7 920 and 5870 loop? It has Noctua fans on it.
Thanks.
Old October 9, 2009, 09:15 PM
SugarJ's Avatar
I had a MCR320 with my GTZ and GFX2 on a GTX285 with acceptable temps. Your triple should be fine. And of the 3 blocks, I'd take an EK over the other 2.
Old October 9, 2009, 09:40 PM
JD JD is offline
+1 for EK. I see Performance-PCs has all of them in stock now too
Old October 10, 2009, 02:45 AM
+1 on that .
Old October 10, 2009, 07:55 PM
Does the EK 5870 block support compression fittings? If so do you recommend them? What are some of the better ones?
Thanks
Old October 10, 2009, 08:28 PM
Pretty sure they would, most EK full cover blocks, in fact.. I can safely say all FC blocks I've seen do support..
For compression fittings, both feser and bitspower have then, I prefer and suggest bitspower.. You could get regular barbs and cheap worm clamps for half the price than a single compression fitting (I think so..) but if you want the looks, and the trouble of not tightening clamps/zip ties... then get them, or if you're budget affords..
Either way can't go wrong..
Old October 10, 2009, 09:33 PM
Some guy on some other site told me my Swiftech triple rad would not be enough to cool my i7 920 and 5870...
Is this guy high or legit?
Is so, then I'd might as well buy a full plate
Old October 11, 2009, 12:59 AM
Apollo4g's Avatar
The EK is the best choice since the liquid goes right over the VRMs of the 5870.
One of the first to do that and its about time. REAL full coverage.
800D | i7 920 | EVGA Classified LE | 5970 EK Waterblock | 12GB - 1600 Dominators DDR3 | Silverstone Decathlon 1200W | Vertex 120GB |
ASUS Xonar HDAV1.3 | Heatkiller 3.0 | Thermochill PA.120.3 | Freezone Elite | 2x655's with EK Dual D5 Top | T-Virus Res |
Old October 11, 2009, 07:04 AM
Dazmode's Avatar
I'm glad that so many people agree that EK is great quality. I like them the most too.
Any triple rad with single GPU is perfectly fine. I like Feser myself. Compression fittings on EK is not a problem.
Orange Build: Final Video
HTPC Build: Final Video
Old October 11, 2009, 03:47 PM
Bojamijams's Avatar
I would never touch anything feser but can and definitely do recommend bitspower. They'll also have a 5870 FC block that will also work with a 5850. Swiftech Komodo is also supposed to fit both types
Computer: i7 2600k @ 4.7Ghz | Asus P8P67 Evo | Corsair LP 16gb 1600CL9 | Silver Arrow | Essence STX | Crucial m4 128gb | Silverstone Raven 3|
Video: 2x R9 290 @ 1050 / 1375 | ASUS VG248QE |
Audio: STX => Audioengine A5 / audio technica AD700X
HD5870 only requiring a 500W psu?!?!? Z Overlord Video Cards 14 October 5, 2009 05:15 PM
Installing a new waterblock shayan288 Water Cooling 20 March 19, 2009 02:17 PM
[WTB] CPU Waterblock Chromey Buy/Sell & Trade 2 December 19, 2008 02:24 PM
[WTB] 9800gx2 waterblock kyle_L Buy/Sell & Trade 0 December 15, 2008 07:14 PM
WTB: waterblock (s) elninio Buy/Sell & Trade 3 August 25, 2008 07:57 AM
