  #21 (permalink)
Old October 9, 2009, 06:04 PM
gingerbee's Avatar
doh missed that.
  #22 (permalink)
Old October 10, 2009, 05:35 AM
8 hours of blend overnight.
  #23 (permalink)
Old October 19, 2009, 08:08 PM
i think i would love to see more people using phase or cascade to cool there cpu's for OC'ing and benching
  #24 (permalink)
Old October 20, 2009, 05:13 AM
gingerbee's Avatar
^ well then get to it ah ha ha
  #25 (permalink)
Old October 26, 2009, 10:56 AM
rai_polo's Avatar
Heh Sascwatch. Try using IC7 Diamond paste, may drop your load temps another 2-3 degrees. Also what fans are you using at what speeds. You really want to use high pressure 38mm fans w/ that rad. Pan Flos / Senkis / Deltas.
  #26 (permalink)
Old October 28, 2009, 04:34 PM
NVM didn't read second page ;)
  #27 (permalink)
Old October 29, 2009, 04:46 PM
now that i actually have a working fan controller back from RMA, i might pick up some new fans. Currently I am using some scythe s-flex SFF21E @ 1200 rpm.
Was thinking about going to something a bit stronger as I can control the fan speed according to my sound preferences and turn them up when stress testing and what not.
maybe one of these:
NCIX.com - Buy Scythe Ultra Kaze 120MM High Static Pressure Fan 38MM 3000RPM 133.6CFM 45.9DBA - DFS123812H-3000 In Canada.
NCIX.com - Buy Delta 120MMX38MM Fan 2900RPM 120CFM 44DBA - AFB1212HHE-F00 In Canada.
  #28 (permalink)
Old October 29, 2009, 04:57 PM
Dazmode's Avatar
Scyther 1200rpm is great fan, but a bit slow for watercooling.... I usually recommend anything above 1500.
38mm fans will perform better the 25mm fan. 55mm fan like Triebwerk can be even more interesting for silent setup. Just make sure power rating is in line with your controller for fans like Delta and San Ace.
Orange Build: Final Video
HTPC Build: Final Video
[WTT] Hows EMT working is it really safe? CactusJoe Buy/Sell & Trade 9 September 14, 2009 03:58 PM
Help with temps! ITaoI CPU's and Motherboards 2 August 16, 2009 05:20 PM
CPU temps vs Core temps sloth CPU's and Motherboards 13 October 19, 2008 12:34 PM
hows HT Omega Striker 7.1 for its price? cmhyt Audio 5 June 1, 2008 09:03 AM
hows an xfx 8800 gt compare to....... rob123 Video Cards 3 March 25, 2008 08:45 AM
