Old August 26, 2007, 02:32 PM
sswilson's Avatar
Default Arctic Cooling Freezer 7 Pro Review Comment Thread
Comments, critiques, general rants????
Drop them in here, we look forward to hearing from you.
If you've just dropped in without reading the review, it can be found here.... http://www.hardwarecanucks.com/hardw...er-review.html
Old August 26, 2007, 02:37 PM
sswilson's Avatar
Why do a review on a two year old piece of hardware?
Some version of this cooler is always being mentioned as a good budget choice for aftermarket cooling, and it was felt that a current review would help new builders decide if this cooler was still worthy of consideration.
Old August 26, 2007, 03:35 PM
Misoprostol
Guest
Posts: n/a
I really enjoyed your review. I often recommend this cooler as an alternative to stock cooling in sub-$1000 machines.
Old August 26, 2007, 03:55 PM
3.0charlie's Avatar
I have bought so many air coolers the last years (10+) that I've been building / oc'ing computers that I have lost track of the number...
But what I can say is that little cooler is the last air type I have bought, and is simply the best best bang-for-the-buck out there. As for the un-conventional harness location, I like it a lot. The extra lenght makes it easy to connect to the mobo, and the extra length can be attached to the fan shroud.
Unlike a Zalman cooler that had a very short (too short for my mobo) wire harness...
Great review!
John
Old August 26, 2007, 04:02 PM
sswilson's Avatar
Great review!
John
The length is fine, I just wish it started at the bottom of the fan shroud to allow for better cable management.
That said, it's hardly a show stopper. This cooler definately makes up for it in price/performance ratio....
When I said that there's no excuse for not including decent aftermarket cooling I meant it.... :)
Old August 26, 2007, 04:09 PM
magictorch's Avatar
Default looks good
I think Im going to give this a go at that price. This looks easier to clean than my current opteron heatsink which is filtering the dust at my home nicely!
Old August 26, 2007, 04:12 PM
sswilson's Avatar
Just be sure to order the A64 model as they don't ship with universal mounts.
This cooler has been around for quite some time, and still has some legs left to it. :)
Old August 26, 2007, 04:24 PM
magictorch's Avatar
Default Aye Aye Captain, A64 it is
At that price if it works I dont care how old it is
3oh6's Avatar
Hardware Canucks Reviewer
good to see a review of it after all this time. when running a local computer store a while back i can't remember how many times i added this cooler (either 775 or AMD version) to builds for people. for the price you pay, you can't beat the silence it offers over stock coolers. i mean, when building a system that comes to even $400~$500 dollars, an extra $25 is nothing for how much noise it removes. it definitely gets my
Old August 27, 2007, 07:02 PM
ebdoradz's Avatar
ive bought the AMD version fo rmy opty. and it does a better job then my bolt-throught Thermaltake cooler that had 2*92fan on it which cost me 60$
for 203$ you definatly cant go wrong
a good lapping job, and a powerfull fan could drop temp by a good 4-5C again. and this fot 10$ more
Gigabyte GA-MA790XT-UD4P / AMD Phenom II x3 720BE @ x4/ Crucial Ballistic DDR3 / Sapphire 4830 5112mb / Corsair 620W PSU / 2*80GB Seagate
DFI LP nF4 Ultra-D / AMD Opteron 165 @ 2.7Ghz/ 2*1GB OCZ Gold GX XTC / Sapphire X1950XT / Fortron 450W PSU / 2*Maxtor 80Gb
ABIT KT7A-RAID / AMD Athlon XP 1800+ @ stock/ 2*256mb PC133/ Geforce 4 mx440 / 250W PSU / Maxtor 20GB
Arctic Cooling MX-2 Comment Thread SKYMTL Water Cooling 14 January 16, 2008 08:56 PM
Comment Thread for PC Power & Cooling Silencer 610 Review SKYMTL Power Supplies 1 January 4, 2008 10:38 AM
does an arctic cooling freezer 7 pro is enought for a Q6600 ebdoradz Water Cooling 2 September 26, 2007 09:09 AM
Comment thread for Arctic Cooling S2 & Turbo Module Review SKYMTL Video Cards 6 August 30, 2007 11:46 PM
