Old October 3, 2009, 12:10 PM
biff's Avatar
Default WC'ing GTX-280 ideas?
Winter's coming which means I'm going to get back to using my comp a lot more, i.e. gaming. I want to WC my 280 and am looking for input. Ofcourse a FC block is a possibility but I'm not big on those. More so because of the cost and I can't take it with me in an upgrade. Id prefer to use a 'univeral' block. I have a maze 5 that I don't think fits, but I could always make it fit I'm sure. But that leaves the rest of the card. I've seen a few unisinks that are for this purpose. How do they perform, are they good enough? Would ramsinks be an option as well?
I don't know how much heat is generated by the rest of the card so I'm at a loss to know if any other options are workable and I don't have major airflow in my case. Any thoughts or suggestions?
i7 4790K @ 4.8GHz w/EK Supremacy Evo
MSI z97 Gaming 5
2x 8GB Gskill Sniper 2133 @ 2400MHz
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Still rockin' the Cooler Master Cosmos on water
Old October 3, 2009, 01:13 PM
MpG's Avatar
MpG MpG is offline
I prefer unisinks over ramsinks where the VRM's are concerned, since they have a larger mass to soak up the heat. But the memory doesn't really get that hot, so it doesn't really matter there. THe other thing to consider is that the backing plate for the card needs to attach to something on the front to keep it there and cool the back memory chips, which ramsinks don't do either.
Regardless, if you're not using a full-cover block, make sure there's at least some airflow over the card (shouldn't be a problem in a Cosmos), since the water won't carry away any heat except from the core.
Old October 3, 2009, 01:52 PM
biff's Avatar
Heh I can't find one anyway. Seems nothing is available for this card.... funny it went obsolete so fast yet there is still stuff available for the 8800's. Look like Ima goin moddin.
MSI z97 Gaming 5
EVGA GTX 280 (SC?)
Old October 6, 2009, 09:57 PM
aviduser's Avatar
Im using these for watercooling my gtx280
D-Tek GFX V2 with g200 plates
D-Tek gtx260/280 uni-sink
Picked em up used for 75 bucks
I5 4670K 4.4ghz - Gtx 780 Amp - 2x4 Corsair Vengeance - MSI z87-g43 - Tx 850w - Asus pbq278q
Old October 6, 2009, 09:59 PM
biff's Avatar
If I could find a unisink I'd prefer to do that, so far no luck.
MSI z97 Gaming 5
EVGA GTX 280 (SC?)
Old October 6, 2009, 10:23 PM
SugarJ's Avatar
Honestly, I'd put up a WTB ad for a 280 waterblock. I did the GFX2 and 32 enzotech ramsinks on my 285, ended up putting the stock cooler back on until I can afford a full cover block because the VRM's got so hot. You can probably pick up a used FC block for what you'd pay for a GFX2 or MCW60 and unisink new.
I did find a unisink at PPC. D-Tek UNI-Sink- nVidia 260 & 280 **New Release** Products Model: U-SINKNV2XX [U-SINKNV2XX] : Performance-PCs.com, ... sleeve it and they will come
Old October 6, 2009, 10:28 PM
biff's Avatar
Thanks for that link.
I've been looking and all the stuff I've been finding say "no longer available". Not looking in the right places I guess. Maybe I will try posting a WTB.
MSI z97 Gaming 5
EVGA GTX 280 (SC?)
GTX 280 vs GTX 280 SLI...Benches rjbarker Video Cards 39 November 16, 2008 04:36 PM
XFX GTX 280 or e-VGA GTX 280 CrimsoN Video Cards 13 October 17, 2008 11:40 PM
GTX 280 vs. GTX 260 vs. 8800 GTX review -n7- Member Reviews 11 September 27, 2008 10:00 AM
