Old August 26, 2007, 05:54 AM
Default Inserting a Pelt under the water bloc?
I am thinking to insert a Pelt between the CPU and the water bloc; is someone as any suggestion about this? 100W ...more or less?
I had the 50W Ultra TEC before and did not get enough cooling with my OC quad...
Intel Core 2 Quad QX6700 OC 3.6GHz
Mobo D975XBX2, 4GB DDR2 800 MHz Corsair TWIN X Dominator
4X 36GB Raptor in RAID 0 (on Intel controller with dual Boot Win32 Pro)
3X 360 GB Seagate No RAID (on Marvell controller for Apps, Paging and Back up)
EVGA GeForce 8800GTS Dual DVI- 2x Monitors 24'' 1920 x 1200
Water Cooling, Ultra X3 1000 Watts PWS.
ASUS Laptop G2S T7700 @ 2.4GHz
Old August 26, 2007, 12:34 PM
Misoprostol
Guest
Posts: n/a
If you want to use a pelt on an overclocked quad, you will be looking at a 450W pelt with a custom block.
I've priced it out and weighed the benefits a few times for myself, and every time I end up deciding it's not going to be worth it.
Old August 26, 2007, 04:58 PM
OK, good to know!
I guess this one at 225W wont be enough??
http://www.ncix.com/products/index.p...cture=Swiftech
Old August 26, 2007, 06:25 PM
MpG's Avatar
MpG MpG is offline
I believe Swiftech's own charts show that the 225W unit has little improvement for a Quad-core, and is actually a little worse than regular watercooling at sustained full-load overclocks.
I'm kind of curious whether Penryn will drop the power consumption enough to make it feasible.
Old August 26, 2007, 09:52 PM
Wankerfx's Avatar
Seriously, ditch the pelt idea, it would be more efficient to go with a water chiller or phase change.
You can get a winstch labs TEC block for ~$200.00 (PCApex.com - Wintsch Labs Arctic Web w-437W TEC)
Then you need to buy a dedicated PSU, a relay, and all the other necessary water cooling parts. (You need a good radiator and good fans, such as a PA120.3 with Sunon fans and a D5 pump)
A somewhat sufficient TEC setup will cost you ~$500.00 for a CPU only loop. Even then, I don't know if a 437W TEC can handle a quad.
[ER]
Old September 8, 2007, 07:09 AM
I hope someone can help. A few months ago, I found a great thread on insulating your motherboard for peletier cooling. I think I linked to the site from here but I'm not sure. It was a very detailed thread with plenty of pics. I remember it was on one of the more well known overclocking sites. Some of the pics involved spreading some non conductive red goop on the back of the motherboard to prevent condensation. @$#$, I should have saved the link. I googled for a couple of hours with no success.
Water Cooling How To?? e_1337 Water Cooling 5 March 16, 2008 01:00 PM
Water cooling kit Vinnie Water Cooling 5 November 12, 2007 09:22 PM
Where the water go... francois methot Water Cooling 10 October 23, 2007 10:57 AM
Another DIY Water Cooling Rig Magnesious Water Cooling 5 April 14, 2007 11:51 AM
