  #21 (permalink)
Old October 2, 2009, 05:55 AM
Dazmode's Avatar
Originally Posted by miggs78 View Post
Yea that hinge.. I thought it was called bracket though :p..
Good Luck there..
I have no clue either.
Orange Build: Final Video
HTPC Build: Final Video
  #22 (permalink)
Old October 2, 2009, 05:59 AM
Dazmode's Avatar
I would flip pump with inlet up and mout res right above it (using bottom hole).
  #23 (permalink)
Old October 2, 2009, 06:25 AM
steers's Avatar
If you use a pump top with a frontside inlet and outlet on the MCP655, you'll be able to put it in the bottom compartment. That's what I'll be doing.
Good luck
Balthasar - Loop: EK Multi 150 > MCP655 w/X-Top2 > Feser X-Changer 360 w/3x Panaflo 68cfm (push) > Heatkiller 3.0 > EK-FC275 > EK-FB Classified
Caspar - 2x Xeon E5504 | SuperMicro X8DAi | 12GB DDR3 | Radeon HD4850 | CM ATCS840
Melchior - Rev. A MacBook Pro | 2.0GHz Core Duo | 2GB DDR2 | Radeon X1600
Bob - Core i3 530 | Gigabyte H55N-USB3 | 4GB DDR3 | Corsair H50 w/ TFC Triebwerk | Silverstone SG06
  #24 (permalink)
Old October 2, 2009, 08:19 AM
I havent tested to see what thread is in the filler hole in the res (i have one at home but havent checked it!) but if its 1/4 thread, id put a barb in the filler hole, get a DD filler port, cut a hole in the top of the case, and pipe the filler up to the top of the res. That allows the res to go alot more places, and you dont care about how to fill it, as you fill it from the top of the case. Works on mine very well. I dont even take off the side cover, just open the filler port and slowly pour in.
I just checked your first post, and looks to be ample room alongside the rad in the top, to fit the filler port. For me, i wanted a setup where i didnt have to remove anything to refill it, and its working a treat for me so far!
AJ's Gamer, Finally finished!
Win 7 64 bit / Antec 1200 / E8400 EK Supreme LT / Xfx 780i SLI / Mushkin 6Gb EM2-6400 - Corsair 3 Fan Cooler / Corsair HX 1000W / 2xSeagate Sata II - Raid 0 / 1xSeagate Sata II - Storage and backup / 2xEVGA GTX285 1Gb- SLI Ek blocks / 2x240 Swiftech Rad, Full Push-Pull / MCP355 w/ Petra Top / Micro Res / Danger Den Fillport Blue / Matrox Digital TH2G / 3xSamsung 226BW's
  #25 (permalink)
Old October 2, 2009, 09:10 AM
CanadaRox's Avatar
All of the threads on the Swiftech Micro-Res V2 are G1/4 so that would work. That is if he wants to drill a hole in his brand new $300 case.
Project: Black and White
  #26 (permalink)
Old October 2, 2009, 09:19 AM
Already took a drill to mine
  #27 (permalink)
Old October 2, 2009, 10:05 AM
The $300 price tag should make you measure twice and cut once lol. Shouldnt stop you from making it your own setup :D
Ena, do you have pics of yours? cheers
  #28 (permalink)
Old October 2, 2009, 10:12 AM
Its in the WIP area.
You won't see where I drilled tho.
  #29 (permalink)
Old October 2, 2009, 01:41 PM
Can I have the pump without a base? Or will it shake?
  #30 (permalink)
Old October 2, 2009, 01:53 PM
SugarJ's Avatar
Zap strap it down, and put a piece of foam under it. Otherwise the vibration will probably drive you nuts. Or look into the UN designs mounting brackets. No, I don't work for them. I just really like the brackets.
Corsair Obsidian 800D Owners Photo Gallery! FiXT Case Mods, Worklog & Gallery 193 April 1, 2011 05:51 PM
So about the Corsair Obsidian, any good strategies for setting up a loop in that? Z Overlord Water Cooling 7 September 21, 2009 08:20 PM
Corsair Obsidian 800D - YouTube Special Sneak Peak FiXT Cases 23 September 7, 2009 08:43 PM
Corsair Obsidian 800D martin_metal_88 Cases 25 August 7, 2009 01:07 PM
Corsair Obsidian Series 800D steers Cases 45 July 12, 2009 01:47 PM
