Old October 1, 2009, 08:07 PM
SugarJ's Avatar
Get one of these. Un Designs Absolute REV3 Pump Mounting Bracket - Mounts Swiftech MCP655/355/350 & Laing D5/DDC/DDC+ - DirectCanada
Now you can rotate the pump and put it wherever you want. You could also get one of these NCIX.com - Buy Un Designs Z2 - Bracket - Mounts Any Un Designs Bracket & Pump to A 120MM Fan - Z2 In Canada. and hang it off any fan.
But I'd put the pump where MpG shows it, and the res in the drive bays. Simplest runs.
Old October 1, 2009, 09:15 PM
I couldn't put the res in the drive bays since my funnel for putting water into res won't fit and I'd have no way to put the water in it :(
So I did this (attachment)
I personally think the pump and the res are flawed.
1. Pump cannot fit in the bottom compartment (it as designed to hold pumps as well as psu's)
2. Res is so unlfexible. I think a mountable cylinder res would do better imo.
Another issue is that the tubing is so thick, I had trouble putting the clamps on all the way on the gpu. It might not be on correctly, so I'm for sure leak testing it.
Old October 1, 2009, 09:26 PM
SugarJ's Avatar
No good. Your res outlet has to be higher than your pump inlet.
I did 2 things when my res was hanging in the drive bays of my 900. 1. Filled the loop, then used the L bracket to mount it. 2. Took the bulb off a turkey baster and used it as a long funnel.
And your pump would fit if mounted on it's side, which is possible with one of the UN designs brackets. I don't remember which one though.
And yes, I find you have more options with a EK or BP cylinder res.
You could also mount your res to the back plate. See red circles.
Old October 1, 2009, 09:37 PM
It'd only be mounted by one hinge though, since the holes are too spaced apart.
Old October 1, 2009, 09:43 PM
MpG's Avatar
MpG MpG is offline
For what it's worth, if you stick a block or two under the front of the case to tilt it back some, you can probably fill the system just fine. It's only during the bleeding process that the reservoir needs to be higher than the pump - once everything is fully bled, that's no longer an issue as long as the reservoir outlet remains underwater.
Old October 1, 2009, 09:45 PM
Use velcro pads on the other bracket.. those extra strong ones, very reliable..
Since you have a rev. 2 res, you could even try to mount the res right above the pump.. and use the bottom port to the pump..
Btw slick setup, if that's primochill tubing, get some UV tubes, honestly the UV effect on those is very cool.. (I have blue primochill myself)..
Old October 1, 2009, 09:49 PM
isn't bleeding emptying the loop? Not so fly on the terminology.
I need some better pump and rad setups.
My case is still new so people have not thought up of strategies for it yet I suppose.
Old October 1, 2009, 09:50 PM
Bracket...? You mean the hinge for the res? Not sure what you're talking about.
Thanks for the ideas guys.
  #19 (permalink)
Old October 1, 2009, 10:06 PM
Yea that hinge.. I thought it was called bracket though :p..
Good Luck there..
  #20 (permalink)
Old October 1, 2009, 11:28 PM
MpG's Avatar
MpG MpG is offline
Sorry, bleeding means to run the system to get the air out of it entirely. Ideally, the air-water mixture enters the reservoir, but only the water goes back into the loop again. in practice, it can take a little bit before everything is fully separated. But that needs to be done before you leak-test everything, and definitely before you fully power up the system.
Corsair Obsidian 800D Owners Photo Gallery! FiXT Case Mods, Worklog & Gallery 193 April 1, 2011 05:51 PM
So about the Corsair Obsidian, any good strategies for setting up a loop in that? Z Overlord Water Cooling 7 September 21, 2009 08:20 PM
Corsair Obsidian 800D - YouTube Special Sneak Peak FiXT Cases 23 September 7, 2009 08:43 PM
Corsair Obsidian 800D martin_metal_88 Cases 25 August 7, 2009 01:07 PM
Corsair Obsidian Series 800D steers Cases 45 July 12, 2009 01:47 PM
