Old September 30, 2009, 07:59 PM
Default How do I clean Waterblocks?
Setting up my new build, reusing water blocks. How do I clean them? I heard I was supposed to before redoing it. Do I have to remove the metal barbs?
Old September 30, 2009, 08:09 PM
MpG's Avatar
MpG MpG is offline
Depends on what sort of gunk you've got in them. If nothing, a little distilled water will be fine. If you want to go to the trouble of taking the block apart, you wash the copper parts (and ONLY the copper) with a little vinegar or ketchup. That's usually just cosmetic, though.
sswilson's Avatar
What kind of block is it? Generally, the best way to clean it is to take it completely apart so that you can clean the individual tines inside the block. If you can't (or don't want to) actually take it apart, I suppose you could just empty a can of contact cleaner into it.....
Old September 30, 2009, 08:17 PM
they seem clean to me, should I just not mess with it?
Old October 1, 2009, 05:08 AM
Dazmode's Avatar
Yes, no need to over do things. If nothing inside sticking to the metal, you will gain nothing with your cleaning effort.
Orange Build: Final Video
HTPC Build: Final Video
Old October 1, 2009, 05:15 AM
gingerbee's Avatar
+1to that no temp gains at all
Clean LCD jay51 Display Units 49 October 4, 2009 11:42 AM
[WTB] NB and SB waterblocks WolfBane Buy/Sell & Trade 20 February 21, 2009 09:25 PM
[FS] Reno's Clean up Sale renoracer Buy/Sell & Trade 1 November 27, 2008 03:14 PM
How Do You Clean Your LCD Monitor? mo' power Display Units 17 November 5, 2007 07:26 PM
Tips to clean radiator eagle_ Water Cooling 2 August 22, 2007 07:28 AM
