Old September 25, 2009, 02:46 PM
Default Smallest ID of tubing
I know most tubing comes in 3/8s but could you go smaller?
Or would flow be really impeded badly?
Old September 25, 2009, 03:08 PM
MpG's Avatar
MpG MpG is offline
There's definitely a little more flow restriction - since your ratio of tubing wall/cross-sectional area goes through the roof, compared to larger tubing. Another issue that is that if the ID of the tubing is small enough, it can actually affect how well components operate (beyond just the issue of flowrate). DDC pumps, for example, needs a certain inlet flow aiming into the impeller to work right (which is why right-angles directly into them can significantly weaken their performance). Impingement-type waterblocks often rely on a certain cross-sectional area of incoming water to operate best, and an incoming stream of water that's only 1/4" wide might not be optimal. I can't find it anymore, but I seem to recall Swiftech used to have graphs for their MCW-60 GPU block, where using 1/4" fittings weakened it's performance, even at the same flowrate as larger sized fitting. Some of Koolance's blocks have separate graphs for 1/4" tubing and larger tubing as well.
That said, I doubt even a worst case scenario would cost you more than a few degrees. If you really need to go 1/4" for clearance reasons, go for it.
Old September 25, 2009, 04:09 PM
Babrbarossa's Avatar
1/4" ID tubing and fitting available at sidewinder
Metal Standard and Compression Fittings
Last time I bought something from there it never came.....
psst, wanna see my binder?
Old September 25, 2009, 06:04 PM
Sushi Warrior's Avatar
You could get much much lower by using other types of tubing not meant for computers, but yeah 1/4 is the smallest size that is still common.
You're half way through some post and you realize it's from some retard who types like he's got an array of dog dicks for fingers
Old September 25, 2009, 11:24 PM
CanadaRox's Avatar
I wouldn't go any smaller than 1/4 in for a cooling system. It should be fine with most pumps designed for 3/8 with the correct barbs (or the wrong barbs and some elbow grease). Beyond that I think you would starting seeing a significant drop in performance.
Project: Black and White
Old September 26, 2009, 04:43 PM
Dazmode's Avatar
Yes, I have some 8 and 6 mm compression ittings that I got by mistake (good price). I have one guy who take them and got tubing from canadian tire. Everything cost him third of normal size.
Orange Build: Final Video
HTPC Build: Final Video
[WTB] 7/16 ID 5/8 OD Tubing enaberif Buy/Sell & Trade 5 September 27, 2009 07:32 AM
Tubing, tubing... what to choose? Dazmode Water Cooling 16 June 23, 2009 02:32 PM
Cutting tubing elninio Water Cooling 11 June 10, 2008 04:14 PM
Fans for WC and tubing Dashock Water Cooling 7 May 5, 2008 10:13 AM
Tygon tubing Dark Water Cooling 5 December 28, 2007 07:42 AM
