Originally Posted by Dazmode I have the same Gigabyte board with full chipset block (3 of them), Supreme and two 285s blocks on single Feser360 in push pull. Cards effect was lesser then I thought, so I'm sure you will be OK.
If not too late I would recommend Scythe Flexes as fans. |
I've already got 10 Zalman ZM-F3's as I got them for $6.40 a piece and I needed 10. They were also found to be pretty good midrange radiator fans as well, whichever guy on XS who does the massive fan roundups. The Yate loons are part of the bundle I got, so I figure I may as well use those too.
As for full chipset, I'll have to pass. Bit on the expensive side and I think the only thing that really needs to get water cooled is the NB, and even that is really not "needed".
