  #31 (permalink)
Old December 29, 2009, 02:05 PM
isnt 34'C a lil hot with Water Cooling?
for 3.2Ghz 955.
i have a Vigor Moonsoon LTIII Heatsink with Dual Fan
and 6 cpu case fan ( 2x 140mm fan ,2x 230mm fan, 2x 120mm fan)
running at 3.2ghz stock clock speed. 955 BE. 1.355V
my temp IDLE only 29'C-33'C full load 100% with PRIME 95. temp never go above 41'C
  #32 (permalink)
Old December 29, 2009, 02:11 PM
Default help find water cooling that suit 955~
thats my system.
try to switch to Water Cooling..
but..cant find any water cooling thats really good and decent cooling for the newer processor.
anyone have any idea? for water cooling...that can cool AMD 955 1.355V below then 27'C idle?
  #33 (permalink)
Old December 29, 2009, 02:47 PM
Soultribunal's Avatar
It all depends too what your Ambient Temperature is too. I would want to know that because there is no cooler besides Phase that is going to lower something below your ambient , that could be why you have higher temps.
Even my 965 runs at 35 degrees idle.
If you want Watercooling that really does the trick, get a Coolit Freezone Elite. That thing can handle any processor out there.
ST
www.realhardwarereviews.com
  #34 (permalink)
Old December 29, 2009, 05:02 PM
ST
my room temp is 21'C highest will be 25'C....
usualy 21'C
and Coolit Freezone Elite doesnt perform very well with that kind of price.
i read the OC3d review...
too pricey and performances 7/10..
i want a liquid cooling that can cold my CPU down to <49'C under fulload on 1.5-1.6V overclock
  #35 (permalink)
Old December 29, 2009, 05:29 PM
MarkOne's Avatar
wait a minute , stupid question, I see they display 4 times the Freq. Multi, VID , don't tell me you can adjust the core individually ? ( keep in mind I never have an AMD since 10 years )
  #36 (permalink)
Old December 29, 2009, 06:15 PM
ya u can do that...but i don think ppl overclock the core individualy
  #37 (permalink)
Old December 29, 2009, 06:18 PM
sswilson's Avatar
Yes it's supposed to be possible, but I didn't have any luck trying to "underclock" a weak core to get a better OC on the others.
As far as temps go....
I've got a reasonably good WC on a 955be and the best I can get out of it at a fairly high OC is 54c on full load. Might be a bad batch (I've got two with the same thermal signature), but they seem to run fairly hot.
  #38 (permalink)
Old December 30, 2009, 05:58 AM
I think you should read the Review of the Freezone Elite that HWC did here.
CoolIT Freezone Elite CPU Cooler Review
Any Peltier unit that can bring something below ambient is well worth the investment. And when you look at what a Proper loop is going to cost you, the Freezone Elite wins out everytime so long as its just the CPU you are cooling.
Regards,
ST
  #39 (permalink)
Old January 2, 2010, 02:32 AM
cozmosland's Avatar
that does seem high.
im running a x2 550 so the same proc just 2 less cores and i am just using swiftechs single 120 kit for now and my idle stock temps were 19 and at load 25?
cant remember but right now im running at 3.8 and currently my idle is 27.5 and at load no higher then 35 and thats while folding usually,
most games bring it to 33.
I5 750 vs. Phenom II 955 bumfloss New Builds 13 December 11, 2009 01:15 PM
phenom ii x4 955 temp? tranceholic CPU's and Motherboards 7 August 30, 2009 11:53 PM
Intel i7 920 or Phenom II 955? AmuseMe CPU's and Motherboards 30 August 13, 2009 05:00 PM
AMD Phenom II X4 955 BE. Good contender to i7? bojangles CPU's and Motherboards 40 June 28, 2009 01:16 PM
NCIX has the Phenom II 945 and 955 up snoosebum CPU's and Motherboards 5 April 22, 2009 11:16 AM
