<~----> PHENOM II 955 WATER COOLING - Page 3 - Hardware Canucks
  #21 (permalink)
Old October 9, 2009, 05:00 PM
Dazmode's Avatar
Supreme LT AMD edition for CPU, Swiftech or EK reservoir.
You also need bunch of barbs or fittings. Should be well under $400
Orange Build: Final Video
HTPC Build: Final Video
  #22 (permalink)
Old October 10, 2009, 10:43 AM
do u know how many barbs / and or fittings i would need? 6+ and what kind of barbs and or fittings. thanks :)
  #23 (permalink)
Old October 10, 2009, 11:23 AM
Dazmode's Avatar
2 burbs for block, 2 barbs for radiator, two barbs for reservoir. Pump has bild in 1/2" barbs, so you have to stick to this size.
So bare minimum 6 fittings. My recommendation would be 4 strength and 2 45 degree angled.
  #25 (permalink)
Old October 10, 2009, 12:03 PM
Dazmode's Avatar
Swiftech barbs longer then TFC barbs, but you can have 10 of TFC for the price of 4 Swiftech.
I personally use compression fittings, because I'm lazy to deal with barbs.
  #26 (permalink)
Old October 10, 2009, 05:03 PM
Hey dan, I would like to know what kind of fan should i use on my TFC Exchanger high perfomance 360 low - med - or high fan.
  #27 (permalink)
Old October 10, 2009, 05:11 PM
I forgot to say something +_+
Swifttech MCP 655-B w ater Pump is designed for 1/2'' Outlet. it is tube 3/8'' ID and 1/2'' OD or 1/2'' ID 3/4'' OD which one is the good one.
Swiftech MCP 655-B Water Pump
  #28 (permalink)
Old October 10, 2009, 05:15 PM
Dazmode's Avatar
WIthout modification 655 pumps take 1/2" tube, like this:
Feser Tube UV Hose - 1/2" ID - 3/4" OD - BLUE (1')
  #29 (permalink)
Old October 10, 2009, 06:20 PM
What about the fan for my TFC Exchnager 360? Low - med - or high speed.
  #30 (permalink)
Old October 10, 2009, 07:53 PM
Dazmode's Avatar
There is no answer on this one. The faster fans - the better performance, how much your ears can take? Having said that Feser benefits better from medium and fast fans.
I5 750 vs. Phenom II 955 bumfloss New Builds 13 December 11, 2009 12:15 PM
phenom ii x4 955 temp? tranceholic CPU's and Motherboards 7 August 30, 2009 11:53 PM
Intel i7 920 or Phenom II 955? AmuseMe CPU's and Motherboards 30 August 13, 2009 05:00 PM
AMD Phenom II X4 955 BE. Good contender to i7? bojangles CPU's and Motherboards 40 June 28, 2009 01:16 PM
NCIX has the Phenom II 945 and 955 up snoosebum CPU's and Motherboards 5 April 22, 2009 11:16 AM
