Old September 23, 2009, 04:54 AM
metalcore's Avatar
Originally Posted by HalifaxPete View Post
When the computer is on, where do you have the computer placed?
I am thinking of possible restricted airflow around the radiator.
Turn the fans on medium and high and see how much the temps drop at each setting.
Could the the rad be air locked?
The reason I asked is because a portion of the rad is higher than the res.
I hope this helps.
Hey HalifaxPete,
Thanks for all replies by the way everyone!!!
I think i figured out what is going wrong with my set up. The exaust fan on the back of the case and the Power supply unit are all blowing a whole lot of hot air into the radiator. Now I am F..ed because I have to rethink how to mount this huge radiator somewhere else. Any ideas will be very welcomed:help:.Thanks a lot again and I will keep you guys updated.
_____________________________________
-Cooler Master HAF X
-Asus Crosshair V
-SAPPHIRE 4890 " CROSSFIRE"
-Corsair H60
-OCZ VERTEX 2 60GB
-Phenom II 955 black
-wd velociraptor 300g sata hd
-wd caviar black 750gb sata hd
-wd caviar green 1000 sata hd
-8gb (2x4) GSKILL RAM
-lg blu-ray drive
-asus dvd/cd drive
-enermax galaxy 1000W PSU
-Kingston card reader
-Windows 7 Ultimate 64bit
Old September 23, 2009, 06:15 AM
metalcore's Avatar
Originally Posted by metalcore View Post
Hey HalifaxPete,
Okay guys, I just tried getting some of the air from the rad and here are the new reading. I also wanted to say that my room temps were wrong at my first post.
the temp in my room were about 25 celsius.
Same thing with the new reading. I guess that once I figure out a way to get my rad away from all the hot air that's coming from the PSU and the exaust fans, I will nail it!! Now this temp is starting to make sence right? Computer in idle and all three fans on about 1200rpm
Any comments?
Thanks again!
-Asus Crosshair V
-Corsair H60
-OCZ VERTEX 2 60GB
-lg blu-ray drive
-asus dvd/cd drive
Old September 23, 2009, 06:38 AM
CMetaphor's Avatar
Quadfather
Much better temps already. Sure you don't want to try adding another 3x fans (even quiet ones)?
OT: Nice bass. Ibanez Saber?
Old September 23, 2009, 06:50 AM
metalcore's Avatar
yeah,
I will try to add 3 more but do you think that it's going to make a big diference?
I am going to google it and see what people have gotten when adding 3 more fans.
Let's see what happens.!!
Bye
-Asus Crosshair V
-Corsair H60
-OCZ VERTEX 2 60GB
-lg blu-ray drive
-asus dvd/cd drive
Old September 23, 2009, 06:56 AM
Actually Metal, you got a very clean and nice looking setup I'll have to admit.. A little bit wire management on the psu cables (hide those red things, from the green effect :P)..
edit: Do you have at least one 120mm on the top, or space to modify one.. If you do, you could mount you're rad there using the rad box as well..
Old September 23, 2009, 11:23 AM
KaptCrunch's Avatar
I guess molson Coors ad in BC is correct metalcore, try placing rad out your window in a few months
Old September 23, 2009, 01:16 PM
metalcore's Avatar
Hahahah..that big rad at your window will definitely freeze all the heat waves that dare to bother your set up! Good job man. But temperatures went down a little here in toronto and my temps went down as well. it seems that this corner where my computer sits doesn't circulate a lot of cold air and to be honest I can't move this giant anywhere else. But yeah, it would be great to have this thing close to my window to breathe lots of cold air!!
-Asus Crosshair V
-Corsair H60
-OCZ VERTEX 2 60GB
-lg blu-ray drive
-asus dvd/cd drive
Old September 23, 2009, 02:50 PM
KaptCrunch's Avatar
i use 50-50 PG for winter summer 10% so no worry of freezing, i'm by yorkdale niebrough
  #19 (permalink)
Old October 1, 2009, 05:10 PM
Dazmode's Avatar
Not the best picture, but looks like very nice mod.
PR: wait... I: wait... L: wait... LD: wait... I: wait...wait... Rank: wait... Traffic: wait... Price: wait... C: wait...
[IMG]chrome://seoquake/content/skin/close.gif[/IMG]
Orange Build: Final Video
HTPC Build: Final Video
  #20 (permalink)
Old October 9, 2009, 04:46 PM
Hey, I would like to buy a watercooling system for now i have a athlon x2 6000 + and i am looking for a CPU Block. Anyone have a suggestion? i might buy a amd phenom II 955
Water Cooling build :
Pump: Switech MCP 655-B water pump90$
Radiator: TFC Xchanger - High perormance triple radiator 360120$
Tube : Red Uv 1/2''
Cpu Block : unknown
Reservoir : unknown
Tell me what u think about this. I am buying the 360 because i might buy a gtx 275/285 soon and put a watercooling systeme on it.
Thanks for saying ifu like it or have preference or anyting that can help me out buying a good watercooling systeme without puting 500 dolars and + on it :)
I5 750 vs. Phenom II 955 bumfloss New Builds 13 December 11, 2009 01:15 PM
phenom ii x4 955 temp? tranceholic CPU's and Motherboards 7 August 30, 2009 11:53 PM
Intel i7 920 or Phenom II 955? AmuseMe CPU's and Motherboards 30 August 13, 2009 05:00 PM
AMD Phenom II X4 955 BE. Good contender to i7? bojangles CPU's and Motherboards 40 June 28, 2009 01:16 PM
NCIX has the Phenom II 945 and 955 up snoosebum CPU's and Motherboards 5 April 22, 2009 11:16 AM
