Old September 22, 2009, 07:06 AM
Default First time water cooling, need a little help picking parts.
While I have read alot about water cooling before choosing to go this route, I still have a few questions regarding which parts to get.
First of all let me list what I want to do with this loop. I would like to cool my i7 920, and my EVGA X58 3X SLI motherboard, possibly the mosfets on it aswell. While I don't want to cool my video cards at this time, It might be a possibility in the future.
Some of the parts i have picked out are:
Feser One X-360 TFC Xchanger Triple 120MM Water Cooling Radiator G1/4
NCIX.com - Buy Feser One X-360 TFC Xchanger Triple 120MM Water Cooling Radiator G1/4 - 4260119641020 In Canada.
Swiftech MCP655 12V Industrial Water Cooling Pump 1/2IN Barbs
http://ncix.com/products/index.php?sku=19862&vpn=MCP655&manufacture=Swiftec h
Primochill Primoflex Pro LRT Black 1/2IN ID 3/4IN OD Tubing (10 Feet)
NCIX.com - Buy Primochill Primoflex Pro LRT Black 1/2IN ID 3/4IN OD Tubing (10 Feet) - PFLEXP10-34-BK In Canada.
Bitspower Black Freezer EIX58NS - for EVGA X58 SLI
HEATKILLER® CPU Rev3.0 1366 LT
EK Waterblocks EK-Multioption RES 250 rev.2
I am not quite sure which fans or coolant to get. I might also pick up a few fill ports to mount for filling/draining my system.
As for fittings, I was going to go try to keep the all black look and pick up some
Bitspower Black Sparkle 1/2in. Compression Fittings for 3/4in. OD Tubing
And probably just some metal barbs for the rad fittings.
All of this is going to go into my new Corsair Obsidian 800D case. And once I get everything I need I should be posting a build log when I get back from my vacation.
Any help would be appreciated.
Old September 22, 2009, 09:22 AM
SugarJ's Avatar
Nice parts. The only thing I'd say is to make sure you've got a spot for that EK250 res. It's bigger than you'd think. I've got one, and ended up getting a replacement tube to make it into a 150 length.
Fans, cheap - Yate Loons from NCIX. Uncheap - Scythe S-Flex. Stick with distilled water for your loop, as that Primochill has an anti-microbial built into the tubing.
As for that Feser rad, dazmode.com has them on for 141.99 right now.
Old September 22, 2009, 09:26 AM
price matched one from Feser One X-360 TFC Xchanger Triple 120MM Water Cooling Radiator G1/4 - DirectCanada
for $139.50, pretty nice price I thought.
As for the size of the rez, i think i should be fine. Guna toss it in a Corsair Obsidian 800d.
was thinking about NCIX.com - Buy Swiftech Hydrx Water Additive Coolant 2 oz Bottle - HYDRX2OZ In Canada. for my coolant and mix it with water 1L pre bottle.
thanks for the input.
Old September 22, 2009, 09:32 AM
SugarJ's Avatar
That's a good price on the rad.
And I had my res in a Cosmos S, and it was a tight squeeze. That's a full size case too.
Old September 22, 2009, 09:37 AM
hmm, I guess I'll have to measure out the case first before ordering a rez.
Probably wont be ordering the last of my loop until the first week of next month, already have the case, tubing, pump, and rad ordered.
Still need to order some barbs/fittings cpu block, motherboard block, fans and the res. Think I will be ordering what I can from Canadian vendors, and the rest from Sidewinder Computers - Supplier of High Quality PC Modding and Cooling parts
Old September 22, 2009, 10:09 AM
On the Rad, get it from Dazmode.. although he's roughly $2 more expensive, he's giving free shipping on it.. so you'll save there.
Check Dazmode on fittings too, I would prefer Bitspower myself, but Feser fittings are pretty good too.. Also has the EK res options.. Actually I think Daz is offering free shipping on orders over some $$.. but I could be wrong.. Though he did mention to me yesterday, he's putting this free shipping promo on selected feser rads.. He's a nice guy, wouldn't disappoint..
quick edit: Most parts you want, including the Heatkiller block.. daz has it too.. :) and he's canadian, so you might save on shipping. PM Dazmode and talk to him first if you want, I've ordered twice from him, and he's been pleasure to deal with.
Old September 22, 2009, 10:49 AM
steers's Avatar
+1. I've ordered from Daz twice now as well, a great experience both times.
Balthasar - Loop: EK Multi 150 > MCP655 w/X-Top2 > Feser X-Changer 360 w/3x Panaflo 68cfm (push) > Heatkiller 3.0 > EK-FC275 > EK-FB Classified
Caspar - 2x Xeon E5504 | SuperMicro X8DAi | 12GB DDR3 | Radeon HD4850 | CM ATCS840
Melchior - Rev. A MacBook Pro | 2.0GHz Core Duo | 2GB DDR2 | Radeon X1600
Bob - Core i3 530 | Gigabyte H55N-USB3 | 4GB DDR3 | Corsair H50 w/ TFC Triebwerk | Silverstone SG06
Old September 22, 2009, 01:01 PM
Yea!! Support our fellow Canuk in his endeavor to supply our community with an alternative to out of country purhcase's !!!!!
John
Old September 22, 2009, 01:12 PM
I have not received my Obsidian yet and am patiently (ok not so patiently) waiting for NCIX to get some in stock.
Anyway I've done a good bit of reading about it and have the manual (I can send it to you if you want). If you install a full size board like the EVGA you will have 110mm from the top of the case to the edge of the mobo.
I'm going with a couple MCR320's, yea I know old school :) But look at the data, the Swifites still perform admirably for their age. And should handle the heat load just fine as I currently use a 220 rad (1200rpm fans)and after running Prime for an hour on a 4.2 ghz 1.38v i7 920 yields a water temp of around 32c. But I do have to remove the front grills/filters in order to maintain that temp.
John
Old September 22, 2009, 02:07 PM
You know the Feser rads are twice as thick as the Swiftech ones, they do provide excellent cooling, but there's nothing wrong with an MCR320, it performs lot better than other rads out there... It really is a very nice rad..
This is how I look at it, mounting a rad inside the case and have the $$ to spend, go with feser, thick rads, bulky to mount outside.. Mounting outside the case, get a swiftech, those are much lighter and easier to mount.
But really those Germans really know how to make proper stuff, Feser is an example, superb quality and well built.
First time water cooling, need advice. Blam Water Cooling 56 July 20, 2009 05:54 PM
Looking For Water cooling parts Phobia Buy/Sell & Trade 10 May 29, 2009 11:23 PM
[FS] FS Water Cooling parts Exmortis Buy/Sell & Trade 14 March 23, 2009 07:34 AM
[WTB] WTB: Water Cooling Parts Aj23 Buy/Sell & Trade 1 March 5, 2009 12:42 PM
[WTB] water cooling parts upsidedown Buy/Sell & Trade 15 January 19, 2009 01:36 PM
