Old September 20, 2009, 10:43 AM
Default Water cooling checks
I hear alot of folks are concerned about water cooling because of horror stories of leaks ect. I captured a picture of a 2 year old water cooling radiator to show why some of these failures could have been avoided with regular maintenance. There is no leaking thus far but as you can clearly see the oring seal is toast.
Code:
Old September 20, 2009, 10:53 AM
That seal looks to be over tightened which has cause premature failure.
Old September 20, 2009, 01:17 PM
gingerbee's Avatar
+1 to that. Maintenance is every 6 months to a year at the longest. if it leaks it's normally your fault
New to water cooling; need help bkh2 New Builds 31 July 25, 2009 08:02 PM
new to water cooling jay51 Water Cooling 13 June 22, 2008 03:10 PM
New to water cooling coreyb Water Cooling 14 April 10, 2008 12:55 PM
Water Cooling How To?? e_1337 Water Cooling 5 March 16, 2008 01:00 PM
