Old September 19, 2009, 04:38 PM
Phobia's Avatar
Default 90 degree fitting
Hey everyone, I've got a quick question. Will it be harmful to my flow rate to put a 90 degree barb connected to the outlet of my mcp355 with xspc top? I would like to have a 90 degree bend right into my radiator.
(whitty saying to be plagiarized at a later date)
Old September 19, 2009, 04:39 PM
3.0charlie's Avatar
No problem. That's my setup.
Hydro-Quebec is salivating...
Old September 19, 2009, 05:06 PM
As John said.. no worries, i'm about to do that too..
Old September 19, 2009, 05:50 PM
Phobia's Avatar
thank you so much guys. One other quick question: Can i orientate my mcp355 top anyway i want? I.e. Turn the top 180* backwards, so the outlet is facing the same way as the cables?
Old September 19, 2009, 06:22 PM
MpG's Avatar
MpG MpG is offline
Yeah, the top can aim any direction. Just make sure that the top+pump isn't upside down, that's all.
Old September 19, 2009, 06:29 PM
Jackquelegs's Avatar
Rule of thumb for pumps. Make sure the intake of the pump isn't pointing downwards.
Yeah use 90 degree fittings conservatively. Use them only if you absolutely need them.
Iapetos
Zephyranthes
Old September 19, 2009, 06:55 PM
Dazmode's Avatar
+1
I always manage to avoid them.
Orange Build: Final Video
HTPC Build: Final Video
Old September 19, 2009, 07:51 PM
I think the only build that I ABSOLUTELY needed 90 degrees was the one with Typhoon III, with the radiator barbs 2in above the outlets.
Iapetos
Zephyranthes
Logitech Announces Four New Speakers with 360-Degree Sound FiXT Press Releases & Tech News 1 July 14, 2009 01:32 PM
Moving to Canada with US Certs/Degree?? smwoodruff0908 Off Topic 18 May 20, 2009 09:32 AM
is it bad to have to many 90 degree fitting kyle_L Water Cooling 4 April 3, 2009 12:56 PM
IFX-14 90-degree rotation. CMetaphor Air Cooling 8 February 6, 2009 02:50 PM
90 degree elbow clips?? frosty Power Supplies 1 May 18, 2008 07:25 AM
