Old September 17, 2009, 10:07 PM
Linus's Avatar
The best analogy I've heard for this (and I'll share it with you) is think of it in terms of a horse running around a track. If the horse runs around the track 10 times in a minute or 100 times in a minute, how much time does it spend in the straight stretches in either scenario?
Answer: exactly the same amount of time.
Slower water NEVER means better cooling, EXCEPT when the cause of the poor cooling is that you're throwing so much pumping power at the problem that the waste heat from the pumps is heating up the water.
Please note: I am not here to provide official NCIX support on these forums.
For faster (and official) NCIX service please contact our customer care team at www.NCIX.com (Canada) or www.NCIXUS.com (USA)
Heatware: http://heatware.com/eval.php?id=25647
Old September 17, 2009, 10:28 PM
Jackquelegs's Avatar
But how much more thermal energy is generated via the air friction with the horse?
That analogy works for the AMOUNT of water that passes through a given point in a loop. You're not accounting in the properties of conductance.
Iapetos
Zephyranthes
Old September 17, 2009, 10:32 PM
Linus's Avatar
Okay, well please demonstrate a loop to me where the heat created by the friction between the water and the tubing would be a factor.
Good luck there, Chuckles ;)
Old September 17, 2009, 10:34 PM
*facepalm*
The thermal energy generated via the horse with the air is the exact opposite operation as cooling a CPU block.
If you bothered to think this through, the friction with the tubing is negligible due to the MINIMAL coefficient of friction the tubing wall has against the laminar flow of the water.
Iapetos
Zephyranthes
Old September 17, 2009, 10:41 PM
Cptn Vortex's Avatar
I think the answer you are looking for is this. Over NINE THOUSAND RADS!@!!
The Vortex H20
Asus X99-E WS/USB 3.0
i7-5820K
3 x GTX 1070
4x4GB Corsair LPX 2666MHZ
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old September 17, 2009, 10:42 PM
UR DOING IT WRONG. IT"S OVER 9000 RADIATORS!!!!!!!1111!!!!
BILLY MAYS APPROVES OF THIS MESSAGE
Iapetos
Zephyranthes
Old September 17, 2009, 10:44 PM
Ok Jackie, I'm gonna let you finish in a bit, but I just want to say, that this thread is the best thread ever. Thanks.
The Vortex H20
i7-5820K
3 x GTX 1070
Watercooling:
Old September 17, 2009, 10:46 PM
Yo Paul, I'm really happy for you, I'mma let you finish but Billy Mays had one of the best memes of all time. One of the best memes of all time!
Iapetos
Zephyranthes
  #19 (permalink)
Old September 17, 2009, 10:48 PM
Linus's Avatar
Originally Posted by Cptn Vortex View Post
Ok Jackie, I'm gonna let you finish in a bit... Thanks.
That's what he said?
  #20 (permalink)
Old September 17, 2009, 10:49 PM
Way to be the anti-lulz
Iapetos
Zephyranthes
Clean your Rads. A lesson Cptn Vortex Water Cooling 23 June 20, 2009 01:44 AM
[FS] Bitspower "bling goodness" D5/655 Mod Kit - BNIB mhw100 Buy/Sell & Trade 6 June 1, 2009 10:18 PM
[WTB] Thermochill rads Frank Booth Buy/Sell & Trade 0 March 20, 2009 06:08 PM
Two Rads? Infiniti Water Cooling 20 June 14, 2008 05:55 PM
Question about Swifttech mcp-655's Nightwings Water Cooling 21 June 16, 2007 07:37 PM
