Old September 16, 2009, 07:30 PM
Exclamation EMI
Hi again folks!
I recently installed an WC cooling system on a mainstream PC.
Here is my stuff:
1 triple swiftech radiator
1 simple xspc radiator
the swiftech industrial pump with an XSPC tank.
3 scythe ultra kaze 120mm on a sunbeamtech fan controller
1 120 mm fan on the simple radiator.
and a few blocks...
I have tested my memory a little with memtest, and no error.
But went I try with OCCT to test I always got error... on different core!
The thing is that I know that the overclock that I do don't need an increase in voltage.
You know I just play safe if everything is okay.
If I try on the stock clock I need to enable spread spectrum (It work!), otherwise I got error.
So where the hell could come those Electromagnetic Interference?
I will try to ''shield'' the surface of my waterblock with a plastic cover and on the heatsink that I putted on my southbridge.
I use non-conductive coolant by the way.
By the way I got a Msi 790fx-gd70 with a phenom II 720 Be!
Old September 16, 2009, 10:21 PM
MpG's Avatar
MpG MpG is offline
Firstly, nothing plastic is going to do jack to stop EMI - metal or nothing. Preferably grounded metal at that. Secondly, are you absolutely certain it was stable before?
Old September 17, 2009, 07:14 AM
Default re
Hi and thanks for the fast response!
Yes, It was stable before at the same place! Same room!
Tested this processor with OCCT high priority until 3,7 ghz at 1,41 volts if I remember correctly.
Was fully stable on stock voltage until 3,4 ghz.
Now that I have installed all my watercooling stuff
Could it be that my case is opened on bold side? that I got PSU wire on my desk?
PS: At the moment I am at 3,3ghz, I play game and everything is fine.
Old September 21, 2009, 06:08 AM
Default found
Simple bios update resolved the problem.
Know that is a Bios that I can't normally download via the msi website ^^ (via their FTP)
Old September 21, 2009, 06:15 AM
bojangles's Avatar
Nice board, nice to hear you solved it. Have fun!
EMI Filtering JD Power Supplies 9 January 29, 2009 07:12 PM
Acrylic case EMI/static discharge concerns serenity Cases 8 October 9, 2008 11:06 PM
