Old August 21, 2007, 01:20 PM
Eldonko's Avatar
Hardware Canucks Reviewer
Yeaaah. I'm just saying what I would do, and have done many times. And for the record the fet sinc works fine with the heatpipes cut, you just need airflow. :rtfm: Take a look at this thread, the guy did a good job cutting the pipes and cleaning it up. P5N-32-SLI-PLUS North Chipset TOO HOT! - XtremeSystems Forums
You could also remove the whole heatpipe system and buy a cheap cooler for SB and MC14 ramsinks (or 2 x EK Asus 3 Mosfet blocks) for the fets.
Cooler Master Hydra 8800 GPU cooler (water block?) discussion thread Misoprostol Water Cooling 9 December 8, 2007 12:27 AM
Another peculiar GPU cooler from Cooler Master: CoolViva Pro Review by X-Bit Babrbarossa Reviews & Articles from the Web 7 March 19, 2007 04:19 AM
