Old September 16, 2009, 04:13 PM
Default Water cooling log/questions
Quick question on the loop..
Rad > Pump (outlet).. Pump (Inlet) to Res (outlet).. Res (inlet) to cpu (inlet).. cpu(outlet) to rad..
is this correct.. just confused by the cpu inlet and outlet part..
Thanks..
Old September 16, 2009, 04:23 PM
3.0charlie's Avatar
res-pump-rad-cpu-res
outlet res - intake pump - outlet pump - intake rad - outlet rad - intake cpu - outlet CPU - intake res
Hydro-Quebec is salivating...
Old September 16, 2009, 04:29 PM
gingerbee's Avatar
+1 to that
Old September 16, 2009, 04:39 PM
Thanks for that.. though usually we can use any port on the rad right.. as in for outlet pump to intake rad and then outlet rad again..
Old September 16, 2009, 04:56 PM
WolfBane's Avatar
Yepp thats very helpful info guys , i am going to cool my GTX 275 in that config as well:)
I USE EMT ONLY
Remember... Four boxes keep us free: the soap box, the ballot box, the jury box, and the cartridge box.
Old September 16, 2009, 05:06 PM
3.0charlie's Avatar
Yes; any port of the rad can be the intake.
Old September 16, 2009, 05:47 PM
Perfect.. Not a log, but some teasers, pretty happy with the routing..
For the res mounting, I had to lift it a little bit, I used a long 6/32 screw, a washer. 3 nuts.. and at the bottom a teeth nut to tighten it.. once it was raised, so easy to route a tube to the cpu block.. also used a feser 45 degree fitting (thanks to Dazmode) to connect the tube to the rad..
Hopefully, leak testing today, if not.. weekend..
Old September 16, 2009, 06:35 PM
Dazmode's Avatar
Nice routing: smooth, no excessive bending with short runs. Good job with handling reservoir mount. Thumbs up for putting it nicely.
Orange Build: Final Video
HTPC Build: Final Video
Old September 17, 2009, 10:36 AM
stoanee's Avatar
When leak testing with everything in the case do you unplug the motherboard 24+8pin? (& jump psu)
heatware
Old September 17, 2009, 10:42 AM
Dazmode's Avatar
I only disconnect wall's power outlet and run pump from external source of power.
Has anyone ever tried routing their pc's heat? Z Overlord Cases 8 August 23, 2009 09:03 PM
Has anyone ever tried routing their pc's heat? Z Overlord Air Cooling 2 July 21, 2009 07:39 PM
Has anyone ever tried routing their pc's heat? Z Overlord Water Cooling 14 July 18, 2009 02:42 PM
Water Cooling Routing help - Two GPU and Chipset futures Water Cooling 6 May 20, 2009 02:19 PM
quick question regarding loop routing donimo Water Cooling 11 February 14, 2009 11:36 AM
