  #31 (permalink)
Old September 20, 2009, 09:48 AM
Phobia's Avatar
Originally Posted by enaberif View Post
Sorry but my MCR220 with 2 generic fans kept my e8600 @ 4.6ghz and above in the low 60s under load and that was pumping learning 1.5v through it.
+1. I've got my MCR220 cooling my q6600 and 8800gts. The q6600 is at 3.2ghz right now (just set the pc up, haven't had time to mess with the overclocking more)
(whitty saying to be plagiarized at a later date)
  #32 (permalink)
Old September 20, 2009, 10:05 AM
Dazmode's Avatar
Sorry if that sounded too negative or offensive... I run MCR220 with i7 @ 3.88Ghz with crappy voltage (my chip is not the best) and MCR didn't cut it for me for my noise to performance liking, while TFC240 did. So, this is just my personal experience. Peace.
Orange Build: Final Video
HTPC Build: Final Video
  #33 (permalink)
Old September 20, 2009, 10:40 AM
gingerbee's Avatar
mcr220 did not work for my i7. but that is because my wife likes it 30c all the time ambient really matters.
  #34 (permalink)
Old September 20, 2009, 10:56 AM
Seriously guys? The i7 dumps so much more heat than a 775 processor so it really doesn't surprise me at all and figured something like this would be so obvious.
  #35 (permalink)
Old September 20, 2009, 01:13 PM
gingerbee's Avatar
mcr220 was fine for my i7/4870 when i had it in my basement but i have moved and the ambient is way higher at my new place so ( i have found that the i7 only generates about 10c more in temp then the c2d. jmo)
  #36 (permalink)
Old September 20, 2009, 01:20 PM
10 degrees is a big bump in difference for heat.
  #37 (permalink)
Old September 20, 2009, 02:10 PM
Thanks for all the comments and help guys.. so I put the card in the mobo to test .. and this is the outcome:
Seems the card was just bending because of the length and since the whole card doesn't get covered by the block, it's just the weight on once side than the other.. As you can putting the card in the slot, it's perfectly straight, and warp anywhere to be seen..
I'm just waiting on some 90 degree barbs so I can finish routing the tubing and have some leak testing going.. I'll remove the block of the mobo, also the psu will be taken out, as far as the video card is concerned, should I be un mounting the block from the card as well or leave it on?
  #38 (permalink)
Old September 20, 2009, 07:23 PM
A little update
  #39 (permalink)
Old September 20, 2009, 08:02 PM
3.0charlie's Avatar
Looking good! Don't forget those worm gear clamps...
Hydro-Quebec is salivating...
  #40 (permalink)
Old September 20, 2009, 08:25 PM
Yeah.. was just going to put those.. I sent you a PM, do you think I make sense lol..
Kinda getting late, can't leaktest at the moment, work tomorrow.. will have to do it when I come back from work tomorrow..
Thanks guys :)
Has anyone ever tried routing their pc's heat? Z Overlord Cases 8 August 23, 2009 09:03 PM
Has anyone ever tried routing their pc's heat? Z Overlord Air Cooling 2 July 21, 2009 07:39 PM
Has anyone ever tried routing their pc's heat? Z Overlord Water Cooling 14 July 18, 2009 02:42 PM
Water Cooling Routing help - Two GPU and Chipset futures Water Cooling 6 May 20, 2009 02:19 PM
quick question regarding loop routing donimo Water Cooling 11 February 14, 2009 11:36 AM
