<~----> Loop routing question - Page 3 - Hardware Canucks
  #21 (permalink)
Old September 19, 2009, 09:22 PM
Dazmode's Avatar
I run my own tests and I was disappointed with MCR line.
Orange Build: Final Video
HTPC Build: Final Video
  #22 (permalink)
Old September 19, 2009, 09:47 PM
Well I'll give it a go and see the temps I get..
Guys, things don't seem to coping with me.. I installed the EK block on the 4870 for a test, and seemed to have a warp.. I didn't overtighten the screws, I only tightened all screws by one increment.
Here's a picture, it was hard getting a picture, so I took this one which you can see towards the end, the card seems to bend a little..
Any idea what am I doing wrong, or what I should do to solve this.. Thanks.
  #23 (permalink)
Old September 19, 2009, 09:51 PM
Phobia's Avatar
I'm no expert on this, but that looks ok to me. I've had 2 cards like that, I put them in and they were fine.
(whitty saying to be plagiarized at a later date)
  #24 (permalink)
Old September 19, 2009, 10:29 PM
SugarJ's Avatar
I think you're ok. You should have seen the kink I had with my 4870 and XSPC block.
  #25 (permalink)
Old September 19, 2009, 11:11 PM
I didn't actually.. I know I sort of felt that since it's on the end of the board where the block ends, so I might be safe.. but I thought of being of the safe side and checking here..
As for loop routing, the only change I should make is to go from intake cpu to outlet gpu and intake gpu to out outlet res..
I guess just like the rad, the intake and outlet ports on the gpu block doesn't mater, correct?
  #26 (permalink)
Old September 19, 2009, 11:17 PM
Jackquelegs's Avatar
On that particular block you're using, the orientation doesn't matter.
Iapetos
Zephyranthes
  #27 (permalink)
Old September 19, 2009, 11:44 PM
Lpfan4ever's Avatar
Take a look at mine and you won't even see your bend anymore.
Originally Posted by encorp
Code:
<firebane> slightly used
  #28 (permalink)
Old September 19, 2009, 11:48 PM
Boy what happened there..
  #29 (permalink)
Old September 20, 2009, 12:20 AM
Sorry but my MCR220 with 2 generic fans kept my e8600 @ 4.6ghz and above in the low 60s under load and that was pumping learning 1.5v through it.
  #30 (permalink)
Old September 20, 2009, 01:10 AM
You're my Fking hero
Iapetos
Zephyranthes
Has anyone ever tried routing their pc's heat? Z Overlord Cases 8 August 23, 2009 09:03 PM
Has anyone ever tried routing their pc's heat? Z Overlord Air Cooling 2 July 21, 2009 07:39 PM
Has anyone ever tried routing their pc's heat? Z Overlord Water Cooling 14 July 18, 2009 02:42 PM
Water Cooling Routing help - Two GPU and Chipset futures Water Cooling 6 May 20, 2009 02:19 PM
quick question regarding loop routing donimo Water Cooling 11 February 14, 2009 10:36 AM
