Old September 17, 2009, 10:50 AM
Originally Posted by stoanee View Post
When leak testing with everything in the case do you unplug the motherboard 24+8pin? (& jump psu)
I use a PSU tester, and the on and off button on the psu.. nowadays most psus do come with a on and off switch..
Old September 17, 2009, 11:03 AM
stoanee's Avatar
I have no external source, sold off all my spares. Need to get pump going without powering up system.
heatware
Old September 17, 2009, 11:12 AM
you only have 2 options, either get a psu tester, or jump the 24 pin.. you don't need to use the 8 pin, just don't have it connected to the mobo...
Old September 17, 2009, 11:25 AM
stoanee's Avatar
Roger, thanks.
heatware
Old September 18, 2009, 10:48 AM
HaDeS
Guest
Posts: n/a
yep just jump the psu.. here's a lnk for you if you need.
How To: Jump Start A Power Supply (PSU) / Test A Power Supply And Components - Overclock.net - Overclocking.net
Old September 19, 2009, 02:31 PM
Sorry one more question.. Is a single MCR 220 good enough to run an E8400 and a 4870 card. I will be cooling the 4870 with my EK FC block, and the processor with a D-Tek Fuzion v1. Pump is MCP655 and a swiftech res v2.
I'm not looking for extreme temps, just going to cool the e8400 to a little past 4.5ghz (just for benching), prolly around 4.0-4.2ghz for daily use..
Thanks..
Old September 19, 2009, 02:57 PM
gingerbee's Avatar
sure is
Old September 19, 2009, 04:37 PM
Phobia's Avatar
you'll have quite decent temps!
(whitty saying to be plagiarized at a later date)
  #19 (permalink)
Old September 19, 2009, 06:57 PM
Dazmode's Avatar
That would depends on speed and number of your fans. MCR is a quite weak performer, but with enough air flow you can milk it for some performance.
Orange Build: Final Video
HTPC Build: Final Video
  #20 (permalink)
Old September 19, 2009, 07:47 PM
MpG's Avatar
MpG MpG is offline
Compared to what?
They're a little more restrictive than most of the competition (still far less than any CPU/GPU waterblock), and I don't think their paint job is quite as durable, but the MCR's will dump heat with the best of them.
Has anyone ever tried routing their pc's heat? Z Overlord Cases 8 August 23, 2009 09:03 PM
Has anyone ever tried routing their pc's heat? Z Overlord Air Cooling 2 July 21, 2009 07:39 PM
Has anyone ever tried routing their pc's heat? Z Overlord Water Cooling 14 July 18, 2009 02:42 PM
Water Cooling Routing help - Two GPU and Chipset futures Water Cooling 6 May 20, 2009 02:19 PM
quick question regarding loop routing donimo Water Cooling 11 February 14, 2009 11:36 AM
