Originally Posted by enaberif Corsair memory cooler is far better. |
Totally agreed.. Or even do a DIY, some screws, nuts, washers and 2 fans would do the trick easily..
Now I know you really want to cool that RAM Hades, but sometimes the safest root is the best.. And honest to god, your RAM just needs active cooling, and trust me.. you can 99% of the push it to the limits..
Cooling a RAM is do-able, but both a PITA, you need special parts (like you already know), tubes.. barbs for that.. And I highly doubt water cooling a RAM would give much more juice than an actively cooled (by fan) RAM..
But the decision is yours, you're the only judge, go ahead if you want, people will still help you if you get stuck.. for sure
