Old September 11, 2009, 10:13 PM
Default Lapping CPU
I've been practicing lapping CPU's, by using some older ones I've got laying around. I use the little black holder that the CPU's come with to hang onto while I'm lapping and it works great.
Problem is, I cant find the one that my i7 920 came with, so I was wondering if anyone had a suggestion on what else could be used to protect the CPU while lapping? I don't want to risk contaminating the pins and screwing up a jewel of a 920 DO that overclocks really well, with really low voltage.
THX
▀olweval
Browser: Intel QX9650 (3.0GHz) | Noctua NH-C12P R | Asus P5E3 Deluxe | 4GB Corsair Dominator DDR3 SDRAM 1800 | MSI 8800 GT | Customized Antec Super Lan Boy | Antec Signature SG850 PSU | Ubuntu x64 9.04
Gamer: Intel i7 920 (2.66) @ 3.6 | Water Cooled Buy Swiftech | ASUS Rampage 2 Gene | 6GB Corsair Dominator 1866 GT's | 2xGTX 280's | Banchetto 101 Bench Table | Antec Signature SG850 PSU | Windows 7 RC1 x64 Ultimate
Old September 11, 2009, 10:20 PM
I've seen some people suggest Painter's tape.
Sushi Warrior's Avatar
Maybe some low-ish tack electrical tape? A piece of plastic taped to it?
EDIT: I would be worried about painters tape leaving little pieces.
Old September 11, 2009, 10:30 PM
CanadaRox's Avatar
When I lapped my E6600 I didn't put anything on the back. I was just sure to clean it extremely well with 99% isopropanol.
Project: Black and White
Old September 11, 2009, 10:58 PM
MpG's Avatar
MpG MpG is offline
Electrical tape is likely to leave a little residue behind, I think. Personally, the times that I've run into that problem, I just didn't bother covering the cpu at all. Of course, I was wet sanding, so dust was a non-issue.
Old September 14, 2009, 07:03 AM
KaptCrunch's Avatar
question have you popped the lid, lap the cores or just lapping IHS
have a wood router ? cut a pocket to fit OD of cpu in a piecse of wood leaving the part expose to lap, tight fit cpu with no play
use glass or marble to wet sand your chip in figure 8 pattern.
Old September 14, 2009, 07:14 AM
Prof. Dr. Silver's Avatar
Yeah, I did something similar. I used a little jewelry box and taped the CPU to it. This way you sand only the CPU and NOT your fingertips. :)
Hardcore Folding at it's BEST! HWC - TPU.... There can be only one team in front! TPU, can you smell our *sses already?
Old September 14, 2009, 07:45 AM
have a wood router ? cut a pocket to fit OD of cpu in a piece of wood leaving the part expose to lap, tight fit cpu with no play
I'm not lapping the cores themselves, don't have the balls for that LOL, but I like your idea of carving a space out of a block of wood, my neighbor is a cabinet maker, so I have access to all the wood tools you can think of, thx for the idea, I would have never thought of that.
▀olweval
Old September 14, 2009, 07:51 AM
That's not a bad idea either, gonna have to rifle through my wife's jewelry collection while she's at the store
▀olweval
can lapping your cpu raise temps up? Shadowmeph CPU's and Motherboards 5 August 5, 2009 01:15 PM
Lapping a CPU mo' power CPU's and Motherboards 16 April 13, 2009 03:58 PM
Lapping my E6600 CanadaRox Case Mods, Worklog & Gallery 19 March 10, 2008 09:03 AM
First try at Lapping! zlojack CPU's and Motherboards 13 February 3, 2008 12:07 AM
Tech ARP's CPU & heatsink lapping guide Supergrover Press Releases & Tech News 4 August 29, 2007 05:21 PM
