Old September 10, 2009, 04:20 PM
Default Thermal Paste
Sorry wasn't sure exactly where to post this...
My AS5 is almost done, looking to get something different now.. I got few options.
AC MX-2 or Gelid GC-1.. I'm really digging the Gelid..
AC MX-2 = $9.99, 4 gram tube
Gelid = $8.83, 5 gram tube..
With that info, the Gelid is probably the best bang for the buck, it comes with an applicator.. As for performance, they are really close.. What's your say?
Old September 10, 2009, 04:41 PM
Jake_HT's Avatar
Proven!
https://store.hardwarecanucks.com/pr...-Compound.html
http://jakeht.deviantart.com/
Old September 10, 2009, 05:27 PM
Shadowmeph's Avatar
Originally Posted by Jake_HT View Post
that stusff seems to work good if you can find any at a local shop hehe
Folder :
ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6i28 CPUs 2x NH-U9DO A3
Old September 10, 2009, 05:41 PM
astrodanco's Avatar
Originally Posted by miggs78 View Post
AC MX-2 = $9.99, 4 gram tube What's your say?
Nothing is easier to apply than MX-2. You can't go wrong there.
I'm currently using Indigo Xtreme. It's a real PITA. It's like having your CPU soldered to your water block.
Old September 10, 2009, 07:17 PM
JD JD is offline
MX-2 or MX-3. No complaints with either, though Vapor and a few others on XS reported MX-3 as being dry and thick, but mine seems to only be slightly thicker than my MX-2.
As for spreading thermal paste, I never have nor do I ever want to. Too messy and too much work. Pea-sized dab in the middle is how I always do it.
Amount of thermal paste - help Chris Air Cooling 6 June 17, 2009 05:18 PM
Thermal paste comparison Technokat Overclocking, Tweaking and Benchmarking 3 April 7, 2009 08:12 PM
Thermal paste for a phenom II Jonwall CPU's and Motherboards 9 February 6, 2009 04:34 PM
your thermal paste method CTA CPU's and Motherboards 25 December 16, 2008 01:12 AM
Thermal Paste??? Salavat23 Water Cooling 6 December 27, 2007 05:43 PM
